Pages: Prev 1 ... 13 14 15 16 17 [18] 19 20 21 22 23 24 Next   Go Down
Author Topic: LOTW  (Read 151695 times)
WA0CRI
« Reply #255 on: December 10, 2012, 01:54:54 PM »
WA0CRI: You should upload your log(s) again. They were clearly lost.
Same happened to me with my CQ WW CW log (1100+ QSOs). I uploaded it again and it was finally processed.
Gary, ES1WST
Gary,
I have uploaded daily logs each day since Nov. 24 and not a single QSO has shown up - date of last QSO is still 11/24/12.
NU1O
« Reply #256 on: December 10, 2012, 02:40:50 PM »
[that was sarcasm, btw]
Really?  I would never have known.
Chris/NU1O
AF3Y
« Reply #257 on: December 10, 2012, 04:43:12 PM »
For what its worth, LOTW now has a LIVE logbook queue status page!
http://www.arrl.org/logbook-queue-status
73, Gene AF3Y
AB8MA
« Reply #258 on: December 10, 2012, 05:26:36 PM »
73, Gene AF3Y
Interesting data there. Every two hours they fall 1 hour 40 minutes farther behind.
NU1O
« Reply #259 on: December 10, 2012, 05:35:34 PM »
73, Gene AF3Y
I just noticed that ( don't know if I missed it before or it is new) and I see them falling further and further behind. They are no doubt getting many logs from the 10 meter contest now. I uploaded mine about an hour ago.  Another 600 QSOs in the que. My December 1st QSOs have now been processed by LoTW but no new QSLs since 5X1NH.
Chris/NU1O
« Last Edit: December 10, 2012, 05:38:18 PM by NU1O » Logged
AD9DX
« Reply #260 on: December 10, 2012, 05:39:15 PM »
73, Gene AF3Y
Chris/NU1O
I wonder if the 10m contest will cause that much of an issue.  The band sucked.
EX, KC9TRM, KB9IRZ
N9KX
« Reply #261 on: December 10, 2012, 07:29:30 PM »
Chris/NU1O
that's alright, if I had been more patient and let you wait 11 days, LoTW would have confirmed it  Wink
WW3QB
« Reply #262 on: December 10, 2012, 08:40:27 PM »
73, Gene AF3Y
I never would have guessed there are so many logs in the queue. I assume today's flood is from the 10m contest. But there are two big storm clouds nearby. There is going to be a rush for year end DXCC endorsements for the yearbook. That's a hard deadline to get applications in (unless extended). And on Jan. 5 there is the RTTY roundup.
WA0CRI
« Reply #263 on: December 11, 2012, 06:35:11 AM »
73, Gene AF3Y
According to the queue, the system is processing logs submitted 12/2/2012.  What happened to my daily logs submitted prior to 12/2/2012?  This is why I wish they would be more forthcoming about what's going on.  It is obvious that not only have logs been lost but some accounts, such as mine, are in effect "locked out".
Help,  Doug  WA0CRI
AB8MA
« Reply #264 on: December 11, 2012, 07:17:33 AM »
2012-12-11 04:01:43 Currently Processing Log Uploaded 2012-12-02 17:58:30
(8d 10h 03m 13s ago)
11 Hours later:
2012-12-11 15:02:34 Currently Processing Log Uploaded 2012-12-02 20:47:52
(8d 18h 14m 42s ago)
Without bringing out the slide rule, I would assume there was some downtime last night.
WB3BEL
« Reply #265 on: December 11, 2012, 07:45:03 AM »
Help,  Doug  WA0CRI
I'd recommend that you log in and select the tab Your Account and then select Your Activity.
Look to see when the last log you submitted is indicated as File Processed.
If you see that a log was processed and you have no increase in your QSO records then there is some other problem.
If you see that a log was processed and you have an increase in your QSO record count but no matches.  Then you might have a logging problem like your time is off due to the time change or maybe some other error on your part.  Could be wrong band or wrong mode or wrong date or ??  Or maybe you just talked to ops who don't use LoTW.
AB8MA
« Reply #266 on: December 11, 2012, 07:46:06 AM »
No sooner than I said all that, one of my SWAINS ISLAND confirmations showed up. Smiley
W5DQ
« Reply #267 on: December 11, 2012, 08:35:33 AM »
73, Gene AF3Y
The other 20 minutes is spent calculating how far behind they are Smiley
Gene W5DQ
Ridgecrest, CA - DM15dp
www.radioroom.org
WA8UEG
« Reply #268 on: December 11, 2012, 09:04:11 AM »
Thread typical of so many in todays society, I want it NOW, don't make me wait or I have to THINK to much to use it. If you are interested in ARRL awards or now WPX (WAZ is on it's way) then live with it. If not upload for those that do (IT'S FREE) if that's to much of a bother then don't, spend the $3.50 or so and send the card direct then wait a few months to get it back. If your not into awards or helping fellow hams then just forget it. life will go on.
N9KX
« Reply #269 on: December 11, 2012, 09:46:47 AM »
It is easy to dismiss complaints as mere complaining; it is another thing altogether to glean the merit from said complaints. LoTW is limping down the road, and anyone with an interest in competent technology or with compassion for technology in need of help has every right to chime in.  As I said, LoTW is a reflection on the ARRL and on amateur radio and could be a shining example of competence and state-of-the-art technology.
So, if those with the power to correct the problems are disinclined to see the problem as important, it could very well be that the complainers are doing the ARRL a huge favor.  This is not a new problem.
If LoTW is *designed* to be 10 days behind -- just put that on the LoTW homepage and request patience for those who expect it to be faster.   Wink
Pages: Prev 1 ... 13 14 15 16 17 [18] 19 20 21 22 23 24 Next   Go Up
