Author Topic: Bias-T power injectors  (Read 4071 times)
K7JQ
« on: November 07, 2012, 02:06:54 PM »
Anyone have any experience using bias-T power injectors (such as MFJ-4116) to run 13.8V from a shack power supply through coax to power a screwdriver antenna motor, thereby eliminating a separate control line? Thanks for any input.
73,   Bob, K7JQ
W9GB
« Reply #1 on: November 07, 2012, 02:17:49 PM »
Bob -
Bias-Tee has been around a long time.
I first saw them in late 1970s for antenna mast mounted TV-FM pre-amplifiers for deep fringe TV reception.
Bias-Tee: Wikipedia
http://en.wikipedia.org/wiki/Bias_tee
Remote DC Power through your Coax Cable Phil Salas – AD5X (ad5x@arrl.net)
http://www.ad5x.com/images/Articles/RemoteDC%20RevA.pdf
You may find this article by K5LAD, of interest
http://www.hayseed.net/~jpk5lad/K5LAD%20Memories/Vols%2031-35/Memories--Vol33.htm
Example, PC Electronics (Ham TV)
http://www.hamtv.com/pdffiles/biasT.pdf
http://www.ece.vt.edu/swe/lwa/memo/lwa0135.pdf
« Last Edit: November 07, 2012, 02:23:59 PM by W9GB » Logged
K7JQ
« Reply #2 on: November 08, 2012, 03:51:07 AM »
Thanks for the info. I'll check into these sites.
73,   Bob, K7JQ
KG4RUL
« Reply #3 on: November 08, 2012, 05:48:44 AM »
It is possible to inject DC power into the coax in either polarity, thereby allowing up/down control of the screwdriver antenna motor and eliminating the separate control cable.  However, you lose the ability to count turns on the motor making it rather hard to return to a previous setting.  Also, depending on the antenna being used, running the motor to the stops repeatedly could cause damage.
