Author Topic: Ameritron Amp Problem  (Read 3122 times)
N3CRP
« on: November 09, 2012, 07:09:26 AM »
When I turn the amp on, the plate current goes to 100 ma and the grid current meter goes negative. I get the same results with all the cables disconnected. I'm driving it with an FT-847 transceiver running about 100 watts. It has always run well until recently. Any clues to what the problem could be?
AD4U
« Reply #1 on: November 09, 2012, 07:28:30 AM »
Which amp?Huh?  Bad tube?
Dick  AD4U
N4ATS
« Reply #2 on: November 09, 2012, 08:24:17 AM »
Replace D-16 right behind the meter on the HV board. (1N4001) use a 1N4006 if you have one
W1QJ
« Reply #3 on: November 09, 2012, 08:45:31 AM »
I think he has one or more bad tubes G-F short.  D-16 makes grid track plate...No?
N4ATS
« Reply #4 on: November 09, 2012, 09:08:28 AM »
I have seen this a lot , when that diode goes bad the needle does go negative... However what made it go was probably a arc or who knows. Its a simple 1 minute test to see if it is bad or not which can save him time.
I had one last week with a shorted diode that went bonkers on 20 meters at a certain load position. Have NO clue why but it did... The tubes were good , I put them in my shop queen and it loaded up fine. Then replaced the shorted diode , put the tubes back in and it loaded just fine.
NO2A
« Reply #5 on: November 09, 2012, 08:58:32 PM »
I suspect if you remove the tube and power up the amp you won`t see any negative grid current. This would indicate a tube short. Like Lou said,if D-16 goes bad both meters track each other(act like the same meter movement). Hopefully if it did arc it didn`t take out any components.
K4DPK
« Reply #6 on: November 15, 2012, 08:19:39 PM »
Grid-cathode short.
Phil C. Sr.
k4dpk
K4DPK
« Reply #7 on: November 15, 2012, 08:26:50 PM »
Just thinking....
I think most of the time (with a 3-500 amp) when these symptoms appear, it's a shorted tube, but I recall a Drake amp I repaired once that was different.  It ran a single 3-500, and one of the ceramic discs that bypassed the filament transformer leads between the choke and the transformer had shorted.
Of course the result was the same, but it took a few minutes longer to find it.
Phil C. Sr.
k4dpk
