Author Topic: PT0S antenna  (Read 3265 times)
K6UJ
« on: November 09, 2012, 12:14:50 PM »
The PT0S DXpedition will be using a yagi variation that I haven't seen before.   It is for 20/15/10 and
looks like vertical elements with radials.  The beauty of it is that it can be used at a low height.
It will be interesting to see how it works for them.  AE5X has a write up on it in his blog:
http://www.ae5x.com/blog/2012/08/02/a-unique-yagi-for-pt0s-dxpedition/#more-9815
Bob
K6UJ
KY6R
Guest
« Reply #1 on: November 09, 2012, 01:14:48 PM »
Over salt water it should be excellent. Over regular dirt - not so much.
K6UJ
« Reply #2 on: November 09, 2012, 04:54:51 PM »
Yeah,  after reading Tom Schillers book I see that the verticals by the sea rule !
For the PT0S location it may be just what the doctor ordered, I hope so, I need this for ATNO  Tongue
Bob
K6Uj
KY6R
Guest
« Reply #3 on: November 09, 2012, 05:11:20 PM »
These guys know their antennas and propagation, thats for sure!
K3VAT
« Reply #4 on: November 09, 2012, 05:34:12 PM »
looks like vertical elements with radials.  ... Bob K6UJ
It's really a yagi-vertical array hybrid.  It's called a GardenBeam: a tri-band vertically polarized parasitic array.  It looks like a cross between a vertical array and a traditional Yagi beam, but is definitely vertically polarized.  Vertically oriented Yagis do perform well from low heights (<5m), but at only higher freq (6M and greater).  This antenna uses a set of vertical elements and a set of horizontal dipole elements, which are sized similarly to the elements of a Yagi. They say that near-optimum mounting occurs only 9 to 10 feet above ground!!  Operation from an ocean side environment is the ideal setting for this antenna, not here in Winchester, VA.
The GardenBeam website says, "This results in a vertically polarized beam antenna that is well balanced and can be mounted at the center of its boom."
Could be something very interesting - even a break through in the use of rotatable vertical polarized antenna systems.
73, Rich, K3VAT
« Last Edit: November 09, 2012, 05:38:12 PM by K3VAT » Logged
NU1O
« Reply #5 on: November 10, 2012, 05:05:42 AM »
Has anybody heard them yet? They had hoped to have the 160 meter antenna up and transmitting on the night of the 9th.
It's a very innovative antenna, indeed.
Chris/NU1O
AF3Y
« Reply #6 on: November 10, 2012, 10:41:34 AM »
Chris/NU1O
They were late departing, so starting on the 10th, I believe.  (Maybe tonite....!)
73, Gene AF3Y
K3VAT
« Reply #7 on: November 10, 2012, 05:36:56 PM »
73, Gene AF3Y
They've been on for a number of hours on 160M (their priority [along with 80M]) and racked up hundreds of top band QSOs.  A bit weak here in VA and noise is up too.
There is another thread on PY0S operations.
GL, 73, Rich, K3VAT
