Author Topic: Bird Termaline Model # 8201 max power in  (Read 774 times)
W3AJJ
« on: November 13, 2012, 11:01:19 AM »
I need a dummy load for my 900w 2 meter amp.  Been looking at the Bird 8201.  I see that it rated at 500w continuous.  Will this handle 900w SSB since it is a lower duty cycle?
AD4U
« Reply #1 on: November 13, 2012, 11:04:46 AM »
500 watts continuous means "key down forever".  The Bird 8201 should EASILY handle the legal limit on a typical SSB duty cycle unless you transmit SSB into it for many hours.
Dick  AD4U
« Reply #2 on: November 13, 2012, 11:41:47 AM »
It will handle it fine.
I use the same load quite often at >1kW PEP on VHF, and have been doing that since about 1978 or so -- hasn't failed yet. Wink
K0IZ
« Reply #3 on: November 13, 2012, 12:20:51 PM »
I have one.  Super dummy load.  I have pumped 3KW into mine for a two minutes continuous with only slight temp increase.
W3AJJ
« Reply #4 on: November 15, 2012, 12:46:56 PM »
Thanks all. Just wanted I wanted to hear.  Now I'll go looking for one.
