Author Topic: Need help on antenna for 10 base radio  (Read 2416 times)
KD0TLI
« on: November 16, 2012, 12:35:27 PM »
Can someone give me some help on build plans for a vertial antenna for 10 base radio ?
Space issues limit me to a vertial.
KE5JPP
« Reply #1 on: November 16, 2012, 12:46:10 PM »
Space issues limit me to a vertical.
If you just want a 10 meter vertical, save your time, money and frustration and buy either an I-Max 2000 or a A99.  Tune it to 10 meters and be done.  Forget the stupid ground plane kits for it that are popular with the CB crowd.
http://www.eham.net/reviews/detail/1376
http://www.eham.net/reviews/detail/1233
Gene
KD0TLI
« Reply #2 on: November 16, 2012, 02:19:33 PM »
Gene,
Yes, I see the Imax is a very popular antenna, and reasonably priced.
Thanks.
KD8TFG
« Reply #3 on: November 16, 2012, 06:40:05 PM »
I have the A99 12ft in the air and running @ only 25w have worked stations 6000+ miles from Ohio great antennae
N8WWM
« Reply #4 on: November 20, 2012, 07:32:51 PM »
Save your money and make a vertical dipole. This antenna might cost 10 bucks or so. Use some imagination and you may just save a bunch of cash. I have seen anything from old speaker wire to aluminum foil wrapped around PVC pipe used as antenna material.
A dipole is just as good as an a-99, no matter what lies people have told or had told to them about that fiberglass POS. The Imax is not much better than the a-99 in performance. Both are overpriced.
The other end of your QSO will never know you are on a piece of wire. Smiley
