Author Topic: New Narrow Band Requirement Question?  (Read 2891 times)
KF6OCI
« on: December 02, 2012, 03:13:23 PM »
Will amateur radios still be able to listen to the narrow bands?
Will it affect anything?
     Dan
« Reply #1 on: December 02, 2012, 04:05:50 PM »
Using a wide receiver to listen to narrow band transmissions will result in lower audio output and you may hear interferrence from stations on an adjacent channel.
KF6OCI
« Reply #2 on: December 02, 2012, 04:51:53 PM »
     Dan
K7WCB
« Reply #3 on: December 04, 2012, 09:14:31 PM »
     Dan
What radio will you be using? Some radios can be programmed for narrowband analog reception.
NA4IT
« Reply #4 on: December 05, 2012, 04:40:49 AM »
You will be able to listen at lower volume, provided the public service or commercial entity doesn't move to a "splinter" frequency, such as 155.5675.
Some radios have a "wide / narrow" setting. This will allow you to hear the ones on non-splinter freqs at the higher volume levels.
« Reply #5 on: December 06, 2012, 06:32:13 AM »
It won't affect anything if you're listening to ham traffic.  Narrowbanding doesn't target ham radio signals, at least not yet--and not ever, if we're lucky.
If you use your radio to monitor out of band signals, though, you just notice reduced volume--as someone already pointed out.
KCJ9091
« Reply #6 on: December 06, 2012, 06:53:18 AM »
At some point there will be a push in the more crowded areas to go narrow to open up more repeater pairs.  A problem which could be solved in many areas if the coordinators would do their jobs and de-coordinate non-existent repeaters.
K1DA
« Reply #7 on: December 06, 2012, 10:38:11 AM »
MORE repeaters with antennas on the back fence?  We don't use the ones we have.
KF6OCI
« Reply #8 on: December 10, 2012, 06:26:58 PM »
  Thanks everyone,
     Dan
« Reply #9 on: December 11, 2012, 04:26:43 AM »
Not to prolong the agony (I'm going to do it anyway!   Grin ) but I don't think you'll see that.  The two meter repeater frequencies have been full in many areas for many years now, and there isn't--with a few exceptions--any sort of move to change to narrowbanding.  It's simply seen as not necessary.  Add to that the amount of equipment that would have to be replaced and/or junked by ham operators, and you'll see that any sort of a move to do that on a national scale would come up against some strong opposition.  It has been done in some small areas, but I don't think you'll see it being widely done for quite some time--if ever.
