Author Topic: FT-450D defective or is operator defective?  (Read 2805 times)
W4FBI
« on: December 05, 2012, 03:55:40 PM »
So, I just received a slightly used Yaesu FT-450D xcvr.
Running through several tests - I find when I go to AM or FM mode, the VFO locks on frequency. I cannot vary the frequency. No the VFO "lock" is not on. And, all modes are available according to the menu (my modes). USB/LSB/CW/DATA all permit VFO to work...
Any 450 guys out there?
thx
KA5IPF
« Reply #1 on: December 05, 2012, 05:42:55 PM »
Have you;
Done a complete reset?
Read the manual?
Clif
K2OWK
« Reply #2 on: December 05, 2012, 11:41:35 PM »
In these modes the DSP/SEL knob changes the frequency.
73s
K2OWK
VA7CPC
« Reply #3 on: December 06, 2012, 12:16:02 AM »
Check the manual.
There's a menu option (on the FT-817 it's "A&FDIAL", I don't know what it's named on the FT-450) that enables, or disables, the main tuning knob in AM and FM modes.
Whatever it's called, set it to "ON".
Yaesu's logic is that AM & FM signals tend to be "channelized", and you should use the click-stopped multifunction knob (the "DSP" knob) to change frequencies in 2.5, 5, or 10 kHz steps.
.              Charles
PS -- you're not the first person to encounter this . . .
W4FBI
« Reply #4 on: December 06, 2012, 05:59:07 AM »
73s
K2OWK
You're correct! Main tuning dial does not work in AM or FM - found it hidden on page 19 of the manual. The DSP/SEL does the tuning. But I found that can be changed in the menu.
Must be a reason for Yaesu to move the tuning to that little dial for AM and FM...
Operator was defective :-) not the xcvr...
Thanks for all the help!
