Author Topic: A Simple ¼ λ Ground Plane for 2m  (Read 975 times)
VU2NAN
« on: December 06, 2012, 12:28:40 AM »
Here's the link.
http://nandustips.blogspot.in/2012/12/a-simple-ground-plane-for-2m.html
Nandu.
« Reply #1 on: December 06, 2012, 06:15:33 AM »
So?  This design (with variations) has been around for years.  This is supposed to be new?
« Reply #2 on: December 06, 2012, 06:47:12 AM »
Nandu,
Looks good and easy to make,  I will be making one for my super modified FT-60 this weekend, that is what I was looking for.
  Thanks, Jim  73  W5JJG
VU2NAN
« Reply #3 on: December 06, 2012, 07:50:50 AM »
Of course not, Chris!
Thanks, Jim!
Nandu.
WA2ROC
« Reply #4 on: December 07, 2012, 05:03:40 AM »
SO-239 with 4 drooping 1/4 wave radials bolted to the mounting  holes with a 1/4 wave vertical  soldered to the center.  You can screw a PL-259 to the SO-239 and mount it to a the highest place you can reach.
Older than dirt!
Dick Pettit
WA2ROC
Durham, NC
"All Vintage Heathkit,
All the Time"
« Reply #5 on: December 10, 2012, 01:30:43 PM »
I like to make these using a so 239 as the center part.  solder the 4 radials into the 4 mounting screwa and the center post holds the verticle part.  and it slides  perfectly in light conduit. and the coax screws in the bottom.
N4CR
« Reply #6 on: December 10, 2012, 04:28:51 PM »
I don't use screws.
Bend the pair of radials in a U shape with a flat bottomed U that is the same width as the holes in the SO-239. Then drop the U in from the top and solder along one edge. Do this twice. Bend the radials out at a 45 degree angle. Solder in the radiator. Trim to tune.
73 de N4CR, Phil
W9GB
« Reply #7 on: December 10, 2012, 06:54:18 PM »
Brass rod available at welding shops (brazing rod) OR craft-hobby stores is often used.
In 1970s, they would also buy glass beads/balls -- heat and place at end of rods for 1970s Bling.
W5WSS
« Reply #8 on: December 10, 2012, 06:59:44 PM »
The antenna is allot different than a Ground Plane.
Since the elevated radials slope downward there is radiation contribution out in the vertical axis.
A Ground Plane incorporates horizontal radials and they cancel all but a remnant of  radiation contribution.
This antenna with sloping radials is better understood as a vertical dipole where two halves are center fed yes and usually the bottom half is symmetrically split into 4 parts.
I just wanted to help clarify that distinction.
This slope radial vertical dipole generates more manifested power expressed as gain beyond a quarter wave ground plane
