Author Topic: Help with my 6146B homebrew CW transmitter please :-)  (Read 5007 times)
N2EY
« Reply #15 on: December 12, 2012, 06:22:07 AM »
Couple of things to check:
1) Accuracy of meter circuit. With the rig off, put a meter of known accuracy in series with a battery and adjustable resistance, in such a way as to simulate plate and grid currents.
2) Are you tuning C1 for a peak of grid current, then adjusting the drive control for 2-1/2 ma? That's the correct procedure.
3) What VR tubes are you using? What is the screen voltage key up and key down? (Low screen voltage results in low plate current).
73 de Jim, N2EY
KC2ZFA
« Reply #16 on: December 12, 2012, 02:13:00 PM »
Don't do this!
The 150 pf capacitor isn't a "bypass". It's part of the bridge neutralizing circuit. Do not increase its value!
The cathode of the 6146 is grounded for RF by its bypasses.
73 de Jim, N2EY
interesting ! I saw the evolution of the posted circuit in the 1975 arrl hb (pg. 172) and there's a 1500 pF in place of the 150 pF and is going to ground instead of going to the cathode of the 6146 (as shown in the 3rd image posted above)...
Could you discuss a bit the relative merits of these two ways ?
73 de Peter
« Reply #17 on: December 13, 2012, 04:21:28 AM »
If you don't neutralise the 6146B, that's how you do it. Neutralising a 6146B isn't strictly necessary below 30MHz in CW, although it is for AB1 SSB use, especially on the higher HF bands. The DX40 didn't neutralise the 6146 and that was fine.  Some positive feedback (but NOT enough to allow it to oscillate!) can help reduce the drive requirements, and that can help especially on 10 metres.
N2EY
« Reply #18 on: December 13, 2012, 06:37:29 AM »
The DX-40 and DX-35, and some other rigs, used a design trick to avoid neutralization: Low driver impedance.
There is a rather complex formula which defines the criteria necessary for a tuned-grid-tuned-plate amplifier to oscillate. The tendency to oscillate increases with increased Cgp, increased gain, increased frequency, and some other factors. And one of the factors is the impedance of the grid circuit.
What the DX-40 and DX-35 do is to use a pi-network between the driver plate and final grid. The output Z of the pi net is quite low, which results in an intentional mismatch and low efficiency. But since the driver tube provides much more RF than the final needs, the low efficiency isn't a problem.
The 6146 in the DX-40 and DX-35 tis therefore stable without neutralization because of the trick.
73 de Jim, N2EY
« Reply #19 on: December 13, 2012, 07:38:29 AM »
Other AM rigs not using particularly low Z drivers that didn't neutralise the 6146 were the UK ones - Panda Explorer, KW Valiant and KW Vanguard, and Labgear LG50. Very few UK rigs used neutralisation in the AM days! Maritime transmitters with three 807s didn't either, even on 22 MHz.
Jim, I think the stability criteria you're thinking of is, for other than a Class C stage
                   gm.2.pi.f.Rg.Rp.Cpg must be less than 2.
gm is the tube  transconductance, f is frequency, Rg is the dynamic resistance in the grid circuit, Rp is the plate load and Cpg is the plate to grid capacity.
With a straight tuned grid circuit, Rg will be QXL, shunted by the plate resistance of the driver, and in Class C, will be reduced further by the grid current.
KC2ZFA
« Reply #20 on: December 13, 2012, 09:19:27 AM »
thanks for the discussion.
Here's two versions of the original schematic in handbooks of the early '70s:
http://postimage.org/image/9gxmodkyf/
http://postimage.org/image/k2oumdxi9/
why did they drop the connection of the grid to cathode through the 150 pF shown in the
original post ?
Peter
KC9KEP
« Reply #21 on: December 16, 2012, 01:59:02 PM »
Thank you everyone for your replies!  I’m still working on debugging this transmitter.  For a 1965 vintage design, this transmitter is making me feel quite dumb!  Following are some findings to date.  I think I’ve responded to all the queries?  (I think I may be experiencing multiple issues here.)
G8HQP – The loading seems to be working from the following observation .. I can “peak” the loading capacitor C4.  The plate current peaks in the middle of C4’s travel but I can only get “close” to 3.4 mA plate reading .. Sometimes I can get 3.0 mA or so (representing about 150 mA of plate current v.s. 170 mA suggested.)
N3QE – When I connect the 6AG7 cathode to ground, the transmitter “fires” every time I key down the 6146B stage.  So, I agree that the oscillator is at least part of my problem.  (Of course, my receiver/monitor can "hear" the oscillator running perpetually.)
G3RZP – I get the same effect with other crystals, but the transmitter seems better behaved at higher frequency (i.e., 40m as compared to 80m).  I don’t have another 6AG7 to try right now.  Yes, grounding the 6AG7 cathode “fixes” the oscillator problem.  BUT .. I have discovered another issue by doing this.  Now, the output section appears to break into some sort of secondary oscillation .. maybe a parasitic when sweeping the Plate and Load capacitors.  ALSO .. I have discovered that the amplifier section (6146B) can be made to oscillate WITH THE 6CA7 completely removed!  This must be input/output circuit feedback or some neutralization failure?
K8AXW – I think the metering is fairly close.  I’ve replaced the 10 Ohm and 470 Ohm resistors for the plate circuit with 1% resistors.  If I set the Plate current to 2.3 mA indicated by the Weston 301 panel meter and measure across the 470 Ohm resistor with a Fluke 8010A, I read 1.105 VDC. ( 1.105/470) = 2.34 mA calculated and the meter displays 2.3 mA which is close.  If I put my Fluke 8010A in series with the Weston 301 meter, the current measurements as close:  Weston 301 = 2.5mA, Fluke 8010A = 2.59mA.  Likewise, if I measure across the 27K Ohm resistor in the Grid circuit (26.5K Ohms measured) I read 71.9 VDC.  (71.9/26.5) = 2.71 calculated, Weston 301 2.5mA displayed.
KC2ZFA – I have not tried this yet.  But I see what you mean.  They’ve also added a 100 Ohm resistor in series with the 6146B grid.
N5RMS – I’ve measured these voltages in 3 modes: TUNE, OP, and OP/DOWN KEY
- Junction of 10K & RFC2:  Tune = 405VDC,  OP = 412VDC,  Downkey = 379VDC
- Screen Pin-6:  Tune = 115VDC,  OP = 137VDC,  Downkey = 108VDC
- Fill pin-5:  Tune = 6.93VAC,  OP = 6.95VAC,  Downkey = 6.82VAC
Note – I have found that the DRIVE measured in TUNE mode needs to be bumped up then in OP/DOWNKEY mode.  The above measurements were made without re-adjusting the DRIVE control.
N2EY – 1.) I think the meter is fairly close now (see comments to K8AXW).  2.)  When in 80m range, peaking C1 will drive the meter off range as the ARRL article says it “probably” will.  They suggest de-tuning C1 to bring the drive down to 2.5mA.  That is what I have to do.  3.)  I am using 0B3 and 0C3 as indicated in the ARRL schematic.  Voltages are as follows:
B+  832VDC Key Up,  750VDC OP/KEYDOWN
Screen  197VDC Key Up,  193VDC OP/KEYDOWN (in CW/125 Watt mode)
Screen  109VDC Key Up,  108VDC OP/KEYDOWN (in PH/75 Watt mode)
I'm including some links to some photographs.  Maybe my layout is bad?  Maybe the oscillator is too close to the 6146 and some shielding
is needed?  I'm using a "temporary" front panel.
Thanks again .. I am in need of some Elmering!
http://www.bignick.net/6146B_Xmitter/back.jpg
http://www.bignick.net/6146B_Xmitter/back2.jpg
http://www.bignick.net/6146B_Xmitter/bottom.jpg
http://www.bignick.net/6146B_Xmitter/bottom2.jpg
http://www.bignick.net/6146B_Xmitter/bottom3.jpg
http://www.bignick.net/6146B_Xmitter/bottom4.jpg
http://www.bignick.net/6146B_Xmitter/bottom5.jpg
http://www.bignick.net/6146B_Xmitter/front.jpg
http://www.bignick.net/6146B_Xmitter/top.jpg
http://www.bignick.net/6146B_Xmitter/top2.jpg
http://www.bignick.net/6146B_Xmitter/top3.jpg
73!
--KC9KEP
GW3OQK
« Reply #22 on: December 17, 2012, 02:16:05 AM »
I congratulate you on the 1st class standard of your construction.
I would maximise the drive control. I dont expect oscillator will start cleanly at low screen voltages, so check it keys perfectly to start with. (With the 6146 removed)
The PA looks like a tuned-plate-tuned-grid oscillator to me and would be bound to burst into violent oscillation when you approached resonance. I would take out or minimise C2, change the 150pf to .01uf. Connect 1K to 10K 2W across C1 and try tuning up again, on 40 metres. That might dampen the circuit enough to get it working on fundamental xtal freqs, but not when you try to double.
Hope your 6146 is still OK. I had serveral go blue and fail in an old tx I bought recently.
BR
Andrew
GW3OQK
« Reply #23 on: December 17, 2012, 02:25:49 AM »
Something else I dont like about the circuit. The key line is going to rise towards full HT on key up. I would try connecting something like 4K7 3W across the key to reduce the voltage until the PA just had some small current like 20 mA on key up.
Andrew
N2EY
« Reply #24 on: December 17, 2012, 06:03:52 AM »
No. The 6AG7 will work properly with the range of screen voltages presented if the tube and other parts are good.
The 6146B stage is neutralized by the combination of C2 and the 150 pf capacitor! Doing what you suggest removes the neutralization and will probably make the transmitter more unstable.
73 de Jim, N2EY
KC2ZFA
« Reply #25 on: December 17, 2012, 07:51:47 AM »
Blue neutralization wire (under the chassis) too long. Can you move the neutralization capacitor to
the other side of the 6146 ?
« Reply #26 on: December 17, 2012, 08:40:52 AM »
KEP:  I looked at the photos of your build and must compliment you on your fine workmanship.  That without a doubt is one of the neatest layouts and wiring jobs I've seen in a homebrew project.
The only thing that bothered me was the final tank coil mounted as it is.  It has one end close to the chassis which to my way of thinking affects the value of the coil.
Of course this has nothing to do with your problem.
But if it's working......................
N2EY
« Reply #27 on: December 19, 2012, 09:13:42 AM »
No, it won't. (This is a common misconception about cathode-keyed tube transmitters).
In a cathode-keyed rig like the one pictured, the voltage across the key only rises to the point where the grid reaches cut-off bias - maybe 50 to 100 volts in the rig pictured.
No need to do that. It opens the door to parasitics and backwave if the oscillator runs all the time.
73 de Jim, N2EY
