Pages: [1] 2 3 Next   Go Down
Author Topic: There's something really wrong when.....  (Read 3833 times)
AB5S
« on: December 22, 2012, 07:50:44 AM »
There's something really wrong when Kenwood 520 and 920s
(or any other "plastic" radio) is considered a "boatanchor."
I think it might be "I'm getting old" disease!   Grin Grin Grin
KE3WD
« Reply #1 on: December 22, 2012, 08:37:25 AM »
Apparently our boats, like our automobiles, have been getting smaller and smaller...
KB2WIG
« Reply #2 on: December 22, 2012, 11:03:37 AM »
Well......  Si is sand isn't it Huh? ??.
klc
« Reply #3 on: December 22, 2012, 01:23:57 PM »
How old to be a 'Boat Anchor'? The FT102 is at least 25 or more years old and has a tube PA and driver - isn't that a 'Boat Anchor'?
And the RF performance is still competitive provided the operator has some nouse, switches out the pre-amp,  and isn't a complete lid...
AC5UP
« Reply #4 on: December 22, 2012, 02:07:57 PM »
.............you say that like it's possible.
Set all knobs fully to the right and start calling CQ!
What do we want?  TIME TRAVEL!
When do we want it?  THAT'S IRRELEVANT!
KC9VZB
« Reply #5 on: December 24, 2012, 07:54:18 AM »
I've been fooling around with the kenwood 520 for a while.it receives and transmits for a while.The drake tr3,a real boat anchor spends most of its time waiting for tubes not much fun in that.It receives a little with vfo having little affect.Manual says just because a tube checks good doesn't mean it will work.So 2 or 3 at a time it gets new tubes.I guess I'll have to dust off signal generator if that doesn't work.300 watts would be great.
AB5S
« Reply #6 on: December 24, 2012, 08:12:36 AM »
re: Drake TR-3
It may not be that all the tubes are bad.
I've seen some abused rigs,
 but never one where all the tubes were bad.
A TR-3 is a fine rig, but many things get old besides tubes,
especially capacitors and high-value resistors.
Gets worse if someone has had a "diddle stick" in it.
Is there a reliable tech available to take a look at it?
Ask around for recommendations.  Most ham communities
have one or two guys that get a rep for knowing
at least something about fixing boatanchors.
Good Luck,
D.S.
KC9VZB
« Reply #7 on: December 24, 2012, 08:59:02 AM »
Threr'd be no fun in someone else fixing it.I'm new to ham but I have allot of experience restoring old radios.I had over 300 tube radios at height of my illness.I'm allot better now,and only have a few. To me its more fun to puzzle a thing out and maby learn sonething new.Once a radio is working,it goes on the shelf.I enjoy the pursuit more than the end.I just got a kenwood 450sat to use if I just want to get on the air.Theres a chart in manual showing resistances at tube sockets.I haven't done that yet.I'll take a look at the high value resistors.I replaced a couple of caps,but its far from being re-capped.
N4NYY
« Reply #8 on: December 24, 2012, 11:22:14 AM »
The boatanchor requirements seem to be shifting. I always thought of them as tube radio, with weight. Then you got the smaller tube radios of the 1960's. The the hybrid radios with tube finals. I am not seem some transistor radios that can be boatanchors, like the Zenith Royal 3000. That is a huge transistors radio. And now with surface mount components, the transistor radios appears to be heading in the direction of boatanchors.
W2WDX
« Reply #9 on: December 24, 2012, 03:58:11 PM »
Essentially I define a "boatanchor" as any radio where all the stages are vacuum tube. Hybrids like the FT-101 and such do not fall into this category.
First of all they are lightweight in relation. Take a radio like a Hallicrafters HT-37, it weighs probably 3 times a FT-101. It also isn't a transceiver, just a transmitter. I could certainly tie a rope around it, throw it overboard and use it to hold my 26' sailboat in place. I think an FT-101 would drag along the bottom. HiHi!!!
Essentially, if it is all tube it's a boatanchor. If it has any transistors it is not. It's not a matter of age, something can vintage but not be a boatanchor. It's not even really a matter of weight. A Gonset Communicator could be considered a boatanchor.
« Last Edit: December 24, 2012, 04:01:21 PM by W2WDX » Logged
K1CJS
« Reply #10 on: December 25, 2012, 06:55:53 AM »
The younger you are, the more the definition of boat anchor shifts.  Myself, I consider that a rig that has ANY tubes in could well be considered a boat anchor.  It depends on how long you've been in the hobby too.
Weight?  Heck, my standby rig--an all transistor Kenwood TS130-SE is heavy compared to some of the newer rigs with a lot more capabilities, but I don't consider it a 'boat anchor.'
N8CMQ
« Reply #11 on: December 26, 2012, 11:24:02 AM »
If you need a special desk just to hold the radios, you might have boat anchors...
Try Hallicrafters HT-32 and SX-101, 70+ pounds each, boat anchor material.
In the past, boat anchors were 6 foot rack cabinets with discrete modules for
the exciter, modulator, amp, and power supply.
Or, as I once had, a 'portable' 75 meter rig with a 100 pound dynamotor power
supply to run the receiver/transmitter/antenna tuner unit.
But for our younger generation, FT-101s and other hybrid radios might be boat
anchors, due to their age, and they have tubes.
It seems every generation has their own definition for boat anchor.
WN2C
« Reply #12 on: December 26, 2012, 02:09:38 PM »
How about the difficulty in getting parts?  Any radio that you have to canabalize another for parts must surely be a boat anchor.  It is getting that way with transistors.  They don't have NOS availability like tubes.
WDX: is a Heathkit HW 16 a boat anchor?  It it all tubes but for some silicon diodes and a transistor that does the switching for xmit/rcv
Rick  wn2c
N8CMQ
« Reply #13 on: December 28, 2012, 10:34:09 AM »
Rick  wn2c
The rig I started with a few decades ago...
It served me well as a novice.
Can you use substitute transistors like NTE?
Or use Partsbase to find your parts?
K5HFG
« Reply #14 on: December 29, 2012, 01:08:01 PM »
I take exception to your classifying the Hybrids as plastic radios. Although, I would not call them boat anchors. They are Hybrid
radios.
Don K5HFG
Pages: [1] 2 3 Next   Go Up
