Author Topic: WOUXUN Channel Search Question  (Read 1039 times)
N8HO
« on: December 26, 2012, 07:10:06 AM »
I recently programed my Wouxun two band HT.  I like the HT, but when I begin scanning the preprogramed frequencies, it will pause at frequencies with activity for about five seconds then continue scanning until it finds the next frequency with activity.  I would like to set it up so that when activity is detected, it remains on the frequency until the activity ceases.  I am using a programming cable with this rig.
KA4POL
« Reply #1 on: December 26, 2012, 07:55:51 AM »
If talking KG UVD1P it is menu 19 set to SE, i.e scanning will not resume.
K1CJS
« Reply #2 on: December 27, 2012, 04:58:09 AM »
Seems like you're talking about scan delay--something that most receivers can do to pick up replies to transmissions.  Five seconds does seem like a long delay, but....  If--IF--you can find it in the menu system on the HT, you may be able to turn that off, or maybe vary the delay time.
W5LZ
« Reply #3 on: January 16, 2013, 09:29:33 PM »
There are three settings for scanning control.  Time delay, carrier delay, and 'search'.  The time delay is that 5 second thingy.  If you want it to stay on that channel until the transmission ends put the 'carrier' setting in.  When the carrier disappears the radio resumes scanning.  I haven't tried it but I think the 'search' feature means that when the radio finds a carrier it stops scanning, just stays there till you hit the scan button again.
 - 'Doc
