Author Topic: FLDIGI audio feedback sound?  (Read 1113 times)
N6SBN
« on: December 26, 2012, 03:17:22 PM »
Imac running FLDIGI,  Kenwood TS-590s using the radio's USB cable.    PSK31 on 6 meters.   The antenna is on the roof some 30' away, 20 feet up.
When I asked FLDIGI to transmit a CQ De KF6BJW, I get a loud tone coming out out the radio speaker.  My computer speakers are off.  The microphone is disconnected from the Radio.  I'm assuming this is an audio feedback loop.  I must have a setting wrong.  Any suggestions which menu to check.
I suppose there's a possibility that I'm suffering RF feedback.  I could try some ferrite beads on the lines.
Thanks in advance.
« Last Edit: December 26, 2012, 03:31:30 PM by KF6BJW » Logged
K3DCW
« Reply #1 on: December 26, 2012, 06:01:44 PM »
Do you have the "monitor" feature turned on on the TS590?  Is that what you're hearing.
Also, check to make sure you have the correct audio source/target selected in Fldigi.
Finally, in Fldigi, go to "Configure", "Sound Card", the select the "Right Channel" tab.  Make sure it is all turned off unless you specifically KNOW 100% that you need one of these turned on.
Hope this helps.
73 de Dave
K3DCW
VA7CPC
« Reply #2 on: December 27, 2012, 09:10:27 AM »
a) Is the rig going into "transmit" mode?
b) Is the sound you're hearing from the rig's loudspeaker a PSK31 signal?  [If you don't know what that sounds like,
. . . . set "fldigi" to send its output to your computer's loudspeaker and listen to it.]
.     Charles
N6SBN
« Reply #3 on: December 27, 2012, 10:14:13 PM »
  It is transmitting.  The red light is on and the power meter jumps to 20 watts.
  It's not a PSK31 signal.  It's a whine which sounds much like a feed back loop.
  I had been checking the right channel to transmit.  I'll discontinue using that setting.
  As mentioned above, I'll have to check the TS-590s "Monitor" setting.
N6SBN
« Reply #4 on: December 28, 2012, 10:24:53 PM »
  I think my Rig Cat  settings may be wrong.
N6SBN
« Reply #5 on: December 29, 2012, 05:27:53 PM »
RigCat was wrong.  Thanks
