Author Topic: MRF150 Source?  (Read 1576 times)
W0DOT
« on: December 29, 2012, 02:06:21 PM »
Does Motorola still make the MRF150 or has it been replaced/discontinued?  Tried to find a source but internet search only returns bazillions of data sheet sources and the sources I found on ebay were either used or "reconditioned".  I'd prefer to use new....
WX7G
« Reply #1 on: December 29, 2012, 04:11:52 PM »
RF Parts stocks them at $49.95.
« Reply #2 on: December 29, 2012, 06:04:17 PM »
A "reconditioned" bipolar RF power output transistor?
Gotta wonder how that could be done.
Use the eleven foot pole, reserved for that which I would not touch with the ten foot pole...
W9GB
« Reply #3 on: December 29, 2012, 06:22:43 PM »
MA/COM is current mfg. of the MRF150 MOS POWER FET 150 W transistor, 50 VDC.
Designed primarily for linear large-signal output stages up to 150 MHz.
Communications Concepts, Inc. sells many of most popular
Motorola RF transistors (now MA/COM, SiRF, or Freescale)
http://www.communication-concepts.com/index.php/components/rf.html
The CCI / Motorola EB104 600 W Amplifier uses the MRF150 RF transistor.
http://www.communication-concepts.com/index.php/amplifiers/eb104.html
MA/COM MRF150 - $64.00 ; $256.00 for set of 4.
http://www.communication-concepts.com/index.php/components/rf/transistors-mrf150.html
MA/COM MRF150 Datasheet
http://www.communication-concepts.com/index.php/fileuploader/download/download/?d=0&file=custom%2Fupload%2FFile-1339373810.pdf
« Last Edit: December 29, 2012, 06:32:36 PM by W9GB » Logged
AA4HA
« Reply #4 on: December 29, 2012, 07:09:22 PM »
Silly, everyone knows you start out by replacing the standard transistor oil with silicone based transistor oil. The electrons travel faster.   Grin
Ms. Tisha Hayes, AA4HA
Lookout Mountain, Alabama
K2DC
« Reply #5 on: December 30, 2012, 03:12:33 AM »
Don't forget fixing all the missing holes.  Those electrons gotta have a place to go.
Don, K2DC
« Reply #6 on: December 30, 2012, 04:00:17 AM »
Don't you have to put some smoke into the capsule?
K9AQ
« Reply #7 on: December 30, 2012, 06:14:34 AM »
There are lots of brand new MRF150's available on Ebay.  They come from distributors in China but I have bought many of them and have always had good results.  I test all my MOSFETs before I install them and so far I have only found one defective one, which the distributor replaced at no cost.  Typical pricing is around $29, a little less if you buy in quantity.
Don
K9AQ
JANIS59
« Reply #8 on: January 01, 2013, 12:13:04 AM »
What is with MRF154 benefits over the Infineon`s DE series 150, 275, 375, 475?
They keep the frequencies up to 100 MHz and thermal load until 1,8kW/piece, thus I see the MRF really benefits only between 100 and 400 MHz.
Or something I missed from my eyesite?
M0HCN
« Reply #9 on: January 01, 2013, 04:48:13 AM »
Note that those are switching parts and not designed for linear service, note also that the 730W thermal rating of the DE475 is given at 25 degrees C case temperature and with a derating factor of 4W/C (The others are worse)......
For RF plasma generators and such in the 13.56Mhz ISM band (clearly what these are designed for) these are a solid choice, but I doubt you would get good performance in a linear amplifier.
TANSTAAFL applies to RF power devices.
73 Dan.
