Author Topic: How calculate L of edge-wound coil?  (Read 1178 times)
W0BTU
« on: January 01, 2013, 03:54:28 PM »
Does anyone know the equation for calculating the inductance of an edge-wound inductor? Here's what I have, and I can't find the formula anywhere. Any help would be appreciated.
What I have is made from silver-plated edge-wound flat conductor .073" thick x .377" wide/deep
Coil is 4.831" OD, 4.077" ID
.250" pitch (4 turns per inch)
23 Turns - 5.75" long
(actually is 22.75" turns, 5.687" long)
It's a rotary inductor - Gates model# 30-VB-2344
TIA
« Last Edit: January 01, 2013, 03:56:43 PM by W0BTU » Logged
« Reply #1 on: January 01, 2013, 04:09:39 PM »
Why not ring it and find out empirically?
« Reply #2 on: January 02, 2013, 01:04:11 AM »
Why should it be that much different to a similar coil wound with round wire? You're not looking for 1% accuracy. ARRL Handbooks for years have had Wheeler's formula in them.
L = 0.2aE2, nE2/(3a+9b+10c)
a is diameter in inches, b is winding length in inches, c is radial depth, n i number of turns and L is inductance in microhenries.
the E2 means squared.
VK2TIL
« Reply #3 on: January 02, 2013, 12:21:08 PM »
I think that the "30" in the part number indicates 30 uH.
As KE3WD suggested, resonating it with a known value of C would be a good check.
I agree, too, with G3RZP; I entered your dimensions, roughly-averaged in the case of the diameter, into an on-line calculator and got 34 uH.
Close enough for jazz!  Smiley
N3OX
« Reply #4 on: January 02, 2013, 02:14:33 PM »
I would try using the self-impedance effective diameter derived here:
http://fermi.la.asu.edu/w9cf/articles/conform/index.html
for a rectangular strip of a certain width to thickness ratio and plug that into your favorite round wire calculator.
Dan
http://www.n3ox.net
« Reply #5 on: January 02, 2013, 04:24:30 PM »
Use of the math is fine when designing and actual parts are not in hand.
When you have the actual coil in hand, a cap, a signal generator and a scope can tell you *exactly* what's going on.
VK2TIL
« Reply #6 on: January 02, 2013, 06:04:05 PM »
Just did a bit more Googling and learned a bit about Gates/Harris inductor part numbers.
For a 30-VB-2344;
"30" = Inductance in uH.
"V" = Variable.
"B" = A winding of 3/8" flat strip/bar with a current rating of 20A.
"23" = Nominal length in inches.
"4" = TPI.
"4" = Nominal diameter (possibly ID).
W0BTU
« Reply #7 on: January 03, 2013, 10:19:06 AM »
Thanks for all the replies! I appreciate it.
It does appear that the extra capacitance between the windings has little to do with the inductance, only the coil's self-resonant frequency.
But somewhere, long long ago in a book far far away, I know I saw the formula specifically for edge-wound coils. :-)
Thank you again for all the useful info.
« Reply #8 on: January 03, 2013, 10:24:20 AM »
There's two sorts of edge wound coils, with different equations applicable. One is a coil as you describe, the other is a pancake, rather like a compressed volute spring. Don't often see them these days.
W0BTU
« Reply #9 on: January 03, 2013, 10:36:50 AM »
Those old pancake coils were used a lot back in the days of spark transmitters.
Photos of my coil are at http://www.w0btu.com/files/misc/Gates_rotary_inductor/ .
« Reply #10 on: January 03, 2013, 11:00:47 AM »
I don't remember the planar or "pancake" coils being called "edge-wound", but
I'll have to go back to my books to see.  I know they had a different formula,
and were used extensively as antenna coils in AM BC receivers (usually wound
flat against the back panel) before ferrite rods became common.
KD0REQ
« Reply #11 on: January 03, 2013, 11:01:21 AM »
RZP, used to call those "solenoid" wound coils back when they had varnished cotton insulation.
W5DXP
« Reply #12 on: January 03, 2013, 11:38:25 AM »
One feature of those coils is that they can simultaneously be used as a loading coil and top hat capacitance. That design won the mobile antenna shootout in El Paso, many years ago.
73, Cecil, www.w5dxp.com
« Reply #13 on: January 03, 2013, 01:19:32 PM »
Imagine a volute spring. Take a piece of strip and wind it over itself, like paper towel on a roll. You now have a strip wound coil: separate the turns to reduce self capacity. Not a solenoid, and not really like the old BC band antennas in that the turns are separated.
VK2TIL
« Reply #14 on: January 03, 2013, 02:48:44 PM »
There has been renewed interest in the old technique of conical coils which have reduced inter-winding capacitance and high self-resonant frequency; coil manufacturers now offer a range of conical coils.
There are some interesting designs being used at multi-GHz frequencies;
http://i49.tinypic.com/15x76ms.jpg
http://i48.tinypic.com/30uvb05.jpg
http://i46.tinypic.com/yfj3d.jpg
I particularly admire the person who thought this one up;
http://i47.tinypic.com/zmgojm.jpg
