Author Topic: dipole orientation  (Read 616 times)
KK4MYT
« on: January 01, 2013, 04:42:21 PM »
If you have room which way would you run a dipole.
I am thinking best for me in VA is to run it. North south.
Or does it matter. Maybe two one n/s and the other e/w
WX7G
« Reply #1 on: January 01, 2013, 04:47:50 PM »
It depends on the band, antenna height and if you want to work the US only or you are a DXer.
K7KBN
« Reply #2 on: January 01, 2013, 05:09:34 PM »
Experiment.  Try it several different ways and see how they compare.
Pat K7KBN
CWO4 USNR Ret.
W5DXP
« Reply #3 on: January 02, 2013, 05:02:22 AM »
My 33' rotatable dipole fed with 300 ohm ladder-line works well on 5 bands, 20m-10m, and the rotor for such is inexpensive. Or you could rotate it by hand until you are satisfied with the coverage.
73, Cecil, www.w5dxp.com
VE7TIT
« Reply #4 on: January 02, 2013, 11:48:57 AM »
If it's up less than 1/2 wavelength, it probably won't make much difference. Probably more significant than height, though, is that if the antenna is inside the house, the pattern will be distorted by wiring, plumbing, and other conductive stuff.
WX7G
« Reply #5 on: January 02, 2013, 12:01:15 PM »
That sounds like a great antenna.  How directional do you find it to be?
W5DXP
« Reply #6 on: January 02, 2013, 01:48:36 PM »
At 40' high, there's a 2-3 S-unit difference broadside vs off the ends. (7-9 dBi maximum gain according to EZNEC.) Super simple to install.
