Author Topic: drake tr3 .33mf cap looks like resistor!  (Read 784 times)
KC9VZB
« on: January 02, 2013, 07:55:23 PM »
I'm going over parts while waiting for my turn on net. changed a few paper capacitors.Checking high value resistors,I found a little short,fat 33meg that showed open,I didn't have one so I soldered 3 -10 megs to make 30 and stuck it in there,turned the power on,and no difference!So I puzzle out schematic and it shows it to be a .33mf.This fix is teaching me a thing or two.Again.My high voltage is higher than specks like 40-50 volts,I thought more is always better.I adapted a heath supply.Could excess b+ cause tubes to cut off?I guess I'll get a resistor in there to back it down,maby in the supply there's a adjustable clamp type.
W9GB
« Reply #1 on: January 02, 2013, 08:26:36 PM »
Replacing Capacitors in Old Radios and TVs
http://www.antiqueradio.org/recap.htm
Strategies to Repair or Replace Old Electrolytic Capacitors
http://www.nmr.mgh.harvard.edu/~reese/electrolytics/
Capacitor color codes
http://www.electronics-tutorials.ws/capacitor/cap_5.html
« Last Edit: January 02, 2013, 08:29:25 PM by W9GB » Logged
N4NYY
« Reply #2 on: January 03, 2013, 08:34:40 AM »
Occasionally, I come across a component that I cannot identify. I think early ceramic caps may pass for resistors or vice versa. In this case, I use the knowledge of AC5UP who has a wealth of experience because he is 100 years old. G3RZP, N2EY, and several others help me when needed.
W4OP
« Reply #3 on: January 03, 2013, 09:15:30 AM »
______________________________
I would run the rig at spec voltages.
Remember, when these supplies were built, the A.C. mains were around 110VAC. Now they run 120 and higher. Measure your filament voltage- it is likely high too. That means more heat and shorter tube life.
I built a bucking transformer for my vintage gear to reduce the mains back to 110 VAC.
Dale W4OP
KB4QAA
« Reply #4 on: January 03, 2013, 09:23:52 AM »
I think the other lesson here is: Always compare the Schematic, the Parts List, the Actual Component markings and measurements before replacing.
« Reply #5 on: January 03, 2013, 10:15:46 AM »
And in the case of the FT102, try to make a correlation between them all!
N4NYY
« Reply #6 on: January 03, 2013, 10:48:22 AM »
They don't always match your. Revisions or bulletins did not always make it to the schematic.
