Author Topic: FT-817ND Won't turn on unless plugged in.  (Read 1740 times)
W4JST
« on: January 03, 2013, 07:10:09 AM »
I have a Yaesu FT-817ND that will not power on. I plug the AC charger into it and it powers on fine. I can then unplug it and I know the battery is fine because it will run for 4-5 hours on the battery before it cuts off.
Why won't it power on without being plugged in?
WX7G
« Reply #1 on: January 03, 2013, 07:33:20 AM »
Have you performed a complete reset?
W4JST
« Reply #2 on: January 03, 2013, 08:50:52 AM »
No I have not. I assume that's in the manual? I'll take a look.
Will that lose the 60 meter memory channels?
W4JST
« Reply #3 on: January 03, 2013, 10:01:11 AM »
Reset did NOT fix it.
Anything else?
K9MOV
« Reply #4 on: January 03, 2013, 03:50:39 PM »
After having the 817 for many years and no problems except haven't been able to keep a Batt. good for over 6 to 8 mo.-- I would think that it may be a Batt. problem. Maybe one cell is bad and with increased R loss in the batt. the voltage may be to low for the radio to turn on, but able to run on the Batt. once it does.
A fast check would be to put the radio on a dummy load, power it up with external supply so the radio turns on and then turn off or unplug the external supply so its running on batt. Put the radio in the FM mode and key the radio, check the menu that it is in the 5 watt mode and you should see 5 watts or near that. Remember to go into menu to set the power to the high power mode. If you can't make close to 5 watts, the battery is bad.
The other thing I would check is-- menu 8 (APO) and menu 49( TOT).
I hope it is as simple as that.
Lane--K9MOV
W4JST
« Reply #5 on: January 03, 2013, 03:55:40 PM »
Thanks Lane,
It seems the radio would not be on for 4 hours if the battery was bad. The voltage was 10.7 or so when I powered it on after a charge. I think after a couple of hours it was around 9.7 or so.
K5TED
« Reply #6 on: January 03, 2013, 09:22:26 PM »
Could be a bad front panel unit. Same thing mine was doing. Yaesu repair depot charged $186 plus shipping to replace.
K9MOV
« Reply #7 on: January 03, 2013, 10:51:29 PM »
Yes, it would seem that your batt. is ok.
Good luck with your problem.  73--Lane
W4JST
« Reply #8 on: January 04, 2013, 07:46:06 PM »
It seems to be working okay now.
If anyone else has any more ideas I'd love to hear it.
W4JST
« Reply #9 on: January 05, 2013, 09:23:04 AM »
It's been working perfect everytime now turning on on battery power for the last couple of days.
Maybe it got too cold in my car and took a couple days in the house to get straightened out?
Anyone else have any experience/ideas?
K9MOV
« Reply #10 on: January 05, 2013, 02:48:04 PM »
I have nothing more to add except very glad it didn't cost you any money--HI
73--- Lane, K9MOV
KCJ9091
« Reply #11 on: January 05, 2013, 03:46:25 PM »
The gremlins got bored and went somewhere else.
