Author Topic: Yaesu FT-1000MP Mark-V Field low out put power  (Read 854 times)
N4NDX
« on: January 03, 2013, 01:14:13 PM »
 Huh I'm experiencing low RF power out when operating barefoot. The radio is only maxing out 80 watts after adjusting the RF POWER dial (VR3003) to its max,  I only gained 10 watt from my previous power out of 70 watts. What could be the problem here?
David/n4ndx
« Reply #1 on: January 04, 2013, 09:00:38 AM »
What is your "load?"  Good 50 Ohm dummy load, or something else?
What are you using to measure output power?
What does the DC voltage measure right at the transceiver (not at the power supply) when you transmit, key-down, on CW for this measurement?
N4NDX
« Reply #2 on: January 04, 2013, 12:11:35 PM »
I'm using a DL2K Palstar as a Dummy load, also using an LP-100A Digital Meter. By the way in 40m and 80m it shows improvement of 106 Watts. According to Mark-V owners when you twick the VR3003 clockwise you can adj it to even close to 200w, not that I want to take it to that extreme but would like 110w more or less since my new amp is a legal limit QRO Amp and needs 110w to make it 1500w happy.
David/n4ndx
« Reply #3 on: January 04, 2013, 02:21:48 PM »
I'm confused.  In your first post you said, "The radio is only maxing out 80 watts after adjusting the RF POWER dial (VR3003) to its max,  I only gained 10 watt from my previous power out of 70 watts."
In this post you said on 40m and 80m it's measuring 106W.  Which is right?  Is it 106W on 80 & 40m and 80W on the other bands?
N4NDX
« Reply #4 on: January 04, 2013, 03:15:09 PM »
Yes 106 watts on 80 and 40 M and 20-10m 80 watts at the middle of each band not on the bands edge.
David/n4ndx
NN4F
« Reply #5 on: January 07, 2013, 11:35:21 AM »
David/n4ndx
I would keep the radio stock and not mess with the extra power, driving the HF2000 at 80watts even should give you close to legal limit, you should probably drive it with about 60watts and get about a kilowatt, more than enough for most occasions, and you'll extend the life of the transistors in the 1000...
N4CR
« Reply #6 on: January 07, 2013, 02:52:06 PM »
Is the internal tuner turned off and fave you tweaked the input tuning on the amplifier to increase power transfer to the amp? Almost every transistor rig created today will cut back power in the face of a poor match to the next stage.
It's only a 100 watt radio so it's pretty close from what you wrote.
73 de N4CR, Phil
N4NDX
« Reply #7 on: January 07, 2013, 08:08:07 PM »
I think I'm going to take Paul's/NN4F advise and just leave the rig stock. I think I can drive close to legal limit with 80w anyway.
David/n4ndx
NN4F
« Reply #8 on: January 08, 2013, 11:06:13 AM »
David/n4ndx
Good Idea David, I have the MkV (200w), and drive an old alpha 78 with about 80watts, and it loafs along at 1kw, with the Mosley I have up, i pretty much get through first time, (once you find were the dx is listening) and now my 200w radio is only used at low power, most I run it to is about 120w if the pile up is small and don't need the amp... FYI some of the 1000mp series parts are starting to run low, i had a close by lightning strike, took out my main cpu, chip is on permanent back order, luckily yaesu had the 1000mp mkv control board in stock, not cheap at $351, so treat your 1000 with kid gloves and it should last a long time....
N4NDX
« Reply #9 on: January 08, 2013, 01:42:00 PM »
Hi Paul
Sorry about your rig, I love mine and hope it would out last me. I chase DX as you can see from my call sign and I've done very well with the 1000MP just hate to spend an hour waiting for an opening, that's why I bought a legal limit Amp. I will basically only use over 1k for new countries only. I was using an AL-811H and was doing well other than sometimes waiting too long to get through.
Thanks aging for slapping me over the head to regained my two senses.  Cheesy
David/n4ndx
