Author Topic: YEASU 530 center pin of duckie broken off inside BNC  (Read 2980 times)
K4PBN
« on: January 07, 2013, 04:51:44 PM »
Have a Yeasu 530 dual bander HT...center pin of rubber duck broken off deep inside BNC of HT. I'd appreciate any suggestions on the best fix.
 K4PBN
N4ATS
« Reply #1 on: January 08, 2013, 02:36:40 AM »
It is very easy to replace the entire BNC...
K9YLI
« Reply #2 on: January 08, 2013, 07:43:14 AM »
thats correct.. it alll unscrews..  the  duck , the  lock nut, then  it pulls apart.
replace the   whole thing or scrounge a center pin  of another  bnc  or   tnc  or maybe evne an   N connector.
KB4QAA
« Reply #3 on: January 08, 2013, 03:23:57 PM »
I suggest using one or two razor blades to push the pin out from the segmented sides.
K9YLI
« Reply #4 on: January 09, 2013, 07:56:58 AM »
 I miss read it.. not in the  duck  , its in the  radio..
and  razor blades  a good idea.
dental picks is you have them..
take two  large  paper clips,  bend out   straight, file the  ends down to a sharp  wedge shape.
use as tools to  slide in the  slots and  work the  pin out..
when i doubt,  make your own tools..
K4PBN
« Reply #5 on: January 09, 2013, 05:07:26 PM »
Thanks to all, will take the back of the HT and see if I can replace the entire BNC.
