Author Topic: TS-711A Rig control  (Read 1067 times)
K2WLO
« on: January 16, 2013, 09:33:31 AM »
I need to make a control wire for my TS-711A VHF rig. A DB9 on one end, and a din pin on the other. Maybe I'm wrong in thinking this is possible, but my logging software has the TS-711A in the list for rig control, but the manual has no info about wiring a cable. Thanks in advance for any info.
73 de John K2WLO
KB9TMP
« Reply #1 on: January 20, 2013, 05:16:47 AM »
There's more to it than just a simple cable. There is a level converter involved in the system also. You might want to give a look at PIEXX for this prebuilt one.
http://www.piexx.com/index.php?main_page=product_info&cPath=7&products_id=23
W9GB
« Reply #2 on: January 20, 2013, 06:29:39 AM »
Kenwood TS-711A Service Manual
http://www.ko4bb.com/Manuals/Kenwood...TS-711-811.pdf
In order to support Computer Remote Control, the OPTIONAL Interface board (IF-10A) must be  attached to the Intel 8255 Programmable Peripheral Interface (PPI) on the Control Unit.
http://www.notpurfect.com/main/ts711.html
Kenwood no longer offers the IF-10A option board, BUT IF your radio already has that board installed, here are the instructions:
http://www.qsl.net/4/4x6on/RADIO%20M...ser-Manual.pdf
IF the 6-pin DIN port is intalled on your TS-711A rear panel :
The Serial Signal Levels are TTL and INVERTED (negative logic).
Conversion to RS-232 (DE-9) requires Inversion (7404, hex inverter) AND Level conversion (MAX232).
IF the IF-10A board is not installed, Piexx sells a modern replacement.
http://www.piexx.com/index.php?main_...products_id=22
Piexx IF-10A style option board instructions for IC-711A
http://www.piexx.com/if10a/ts811i.html
w9gb
K2WLO
« Reply #3 on: January 21, 2013, 04:24:51 PM »
Thanks for the great info guys. When I purchased the radio a 6pin din was sent with it. The fella said I would probably need it. Now I have to investigate to see f has the optional board.
John K2WLO
W9GB
« Reply #4 on: January 22, 2013, 02:43:36 PM »
John -
The 1996 ARRL Handbook, Chapter 22, page: 22-47 has Kenwood Interface schematics to DIY build a Kenwood radio to computer RS-232 serial interface.  6-pin DIN to RS-232 (DE-9 connector).
The interface uses the Maxim MAX232 IC (serial signal level conversion) and PS-2501-1NEC [4] (signal inversion and isolation) for TxD, RxD, CTS, and RTS lines from the 6-pin DIN on the Kenwood radio.
Only 5 pins are used on the 6-pin DIN, the 4 previously mentioned data and control lines, plus Signal GND.
Universal Serial Bus (USB) conversion from the radio's 6-pin DIN is a bit more complex.
You need to use a serial UART to USB, such as the FTDI FT230X USB Bridge IC
http://www.ftdichip.com/Products/ICs/FT230X.html
and then use a hex inverter (7404) or isolation / inversion components (as above) required for these Kenwood radios.
http://www.ftdichip.com/Support/Documents/DataSheets/ICs/DS_FT230X.pdf
FTDI is one of the better mfg. for USB Bridge ICs and the industry's best VCP (Virtual COM port) drivers for various computer operating systems (OS).
w9gb
« Last Edit: January 22, 2013, 03:24:23 PM by W9GB » Logged
