Author Topic: Morse mystery from 1947  (Read 1545 times)
K0OD
« on: May 24, 2009, 09:33:24 AM »
"The crew maintained Morse-code radio contact with the ground for the duration of the flight, and just before it was scheduled to arrive they signalled their approach. But then a mysterious signal was received at Santiago airfield—comprising the letters "S-T-E-N-D-E-C". Aware of no such Morse abbreviation, the radioman at Santiago requested a repeat of the signal, and the same cryptic message was received twice more. This inexplicable message was the last one received from flight CS-59"
Then The Star Dust vanished for 50 years
http://www.damninteresting.com/?p=876
AH6GI
« Reply #1 on: May 24, 2009, 12:04:10 PM »
My guess is STENDEC is
ST  = V but the spacing is off.
EN  = R
DE  = DE
C   = C
V = warming up the wrist.
R = Received, as some say these days. I've heard EN for R since the 1960's.
DE C perhaps de Cs-59 or de Cook.
donnno, it's a mystery.
de ah6gi/4
« Reply #2 on: May 26, 2009, 10:06:11 AM »
If this is the incident I think it was, my question is was there a major ionospheric disturbance that day? There should be records of this. And there should be amateur radio logs that note a disturbance if there was one.
If there was a major disturbance that caused a large near-DC magnetic field in the ionosphere it could have alterned the aircraft compasses. It could also have led to a long delayed echo (LDE) of the radio transmission. These are said to come in two time delays for such close transmissions. 0.7 and 3 seconds. Could a 3 second LDE could cause an overlap of STARDUST to be copied as STENDEC?
K0OD
« Reply #3 on: May 26, 2009, 12:09:20 PM »
Surely radio disruptions would have been noted at that time. This was a well publicized mystery in South America and the UK (because of the missing British Messenger).
"Could a 3 second LDE could cause an overlap of STARDUST to be copied as STENDEC?"
Clever idea, but reports indicate STENDEC was copied three times and strongly.
K5END
« Reply #4 on: May 26, 2009, 01:14:20 PM »
...or maybe the radio op's bug was malfunctioning and he did not know it...
« Reply #5 on: May 26, 2009, 02:54:50 PM »
They used hand keys on aircraft. STENDEC? Isn't it obvious?
K5END
« Reply #6 on: May 27, 2009, 01:23:52 PM »
"Isn't it obvious?"
Isn't what obvious? <g>
