I agree 900mA per device seems like alot, but without further information I would be inclined to trust the application note intially, and then take it from there.
I have not used these particular transistors, but based on other 48V type MOSFETs, 900 mA seems entirely appropriate for some class AB operation point with very high (-25 dBc) IMD. Lower bias will give even worse IMD unless lots of negative feedback is being used (you will note that lots of negative feedback via transformer windings is a common theme in many of the lower IMD MOSFET amps.)
