Author Topic: Headlight bulb load quickfix  (Read 3294 times)
VU2NAN
« on: January 18, 2013, 10:54:24 AM »
Here's the link.
http://nandustips.blogspot.in/2013/01/headlight-bulb-load-quickfix.html
Nandu.
« Reply #1 on: January 18, 2013, 12:13:29 PM »
If you connect the bulbs one at a time, rather than all at once, you can often
avoid this problem because the supply only sees the surge current from one
bulb at a time.
KI0BK
« Reply #2 on: January 20, 2013, 09:12:22 AM »
Does this power supply have an over-voltage crowbar circuit, (astron's do).  If it does, a poor solder or loose connection made during the repair may cause the voltage to rise and trip the crowbar.   Look for loose or poor solder connections using an ohm meter (with the power supply off and caps discharged).
Hope that helps.
Jim ki0bk
