Author Topic: Hammarlund HQ-170 Clock  (Read 1307 times)
KB3ZZP
« on: January 22, 2013, 10:35:05 AM »
I am new to this site and ham radio in general.  I own a Hammarlund HQ-170 and was curious if anyone was aware of a place that I could buy a replacement clock.  I am aware of another Hammarlund with such a replacement clock that is battery powered, however the present owner bought it after the clock was changed out.  I fully understand that any such replacement clock will not turn on the radio as the original clock did, however I don't even keep power to this receiver unless I am going to use it.  Any info. is much appreciated.
« Last Edit: January 22, 2013, 10:38:58 AM by WNEWBIE » Logged
AD4U
« Reply #1 on: January 22, 2013, 11:08:58 AM »
I have an HQ-180A and have been looking for a clock for more than 10 years.  I have never seen a clock sold separately, but I guess some have been.  There is no replacement clock except the one(s) you mentioned.  The only way to get an original working clock is to buy a parts radio that has a working clock or find somebody who is parting out a receiver.
Dick  AD4U
KB3ZZP
« Reply #2 on: January 22, 2013, 11:33:56 AM »
I have read enough threads on the internet about folks looking for clocks for these radios that you'd of thought some entrepreneur would have put together a replacement clock by now.  Guess not.  Thanks for the info.
KD0REQ
« Reply #3 on: January 22, 2013, 12:04:35 PM »
that's a plain old Telechron clock, right?  a little oil on both motor bearings (Oilite) and on all of the shafts of any gearing  may do you wonders.  since the clocks were apparently custom-made for Hammarlund and have been Unobtainium for 30+ years, worth a shot.
you might find looking in the back of a vintage aka thriftshop clock radio of a US brand what looks like a similar clock.  there were several sizes of Telechron mechanisms, and the dial face was customizeable.
AC2EU
« Reply #4 on: January 22, 2013, 12:04:51 PM »
I don't think  that those old AM receivers have much resale or antique collectable value, so why not do a retrofit?
One non-destructive way is to remove the old clock and affix a modern LCD type that will cover the hole or make a baffle that will hold a smaller clock? I always thought that the clock made it look like a old kitchen stove anyway...
W9GB
« Reply #5 on: January 22, 2013, 12:19:14 PM »
Telechron Electric Clock for Hammerlund HQ series
http://www.ebay.co.uk/itm/Hammarlund-Telechron-Electric-Clock-for-HQ-170-HQ-180-Receivers-VG-Works-/140890456478?pt=US_Ham_Radio_Receivers&hash=item20cdb9c19e
Hammerlund Parts
http://marketplaceadvisor.channeladvisor.com/StoreFrontProfiles/DeluxeSFShop.aspx?c=620524&sfid=86409&sid=201301221523540000000910270397
Hammerlund HQ-series battery operated clocks (2005) with the proper Hammarlund face.
Roberta Hummel, KA9OSA
202 Midvale Drive
Marshall, WI 53559-9616
(no email)
Clockparts.com (cat. # MVT7130A) movement $6.95
The hands were black, not perfect but OK (cat. # HND1213B, 1 inch long).
You have to modify Hammerlund clockface logo (BAMA) for 12 hour.
http://cart.clockparts.com/americanmademiniquartzmovements-p-685.html
Clock crystals (replacement)
Vacuum formed crystals (lenses), as of 2005.
E. C. (El) Spencer, W8VHF
2074 W Fountain Rd
Scottville, MI 49454
w8vhf@t-one.net
Mike Souhrada, WB9IOG
wb9iog@revealed.net
Has made replacement crystals in past (2005)
« Last Edit: January 22, 2013, 12:29:44 PM by W9GB » Logged
KB3ZZP
« Reply #6 on: January 22, 2013, 12:35:48 PM »
Wow... great info all.  Thanks!
KB3ZZP
« Reply #7 on: January 22, 2013, 12:40:27 PM »
FYI - The email address for:
2074 W Fountain Rd
w8vhf@t-one.net
came back as undeliverable.
KE3WD
« Reply #8 on: January 22, 2013, 12:50:16 PM »
Listen to this good advice.  Unless the coil that drives the motor is shorted or open, which is actually super rare in my experience, a good cleaning and proper lubrication can often restore these old electromechanical gems to like new operation.  For another 30 years.
Clock cleaning was at one time, a small business.  And it did not only include the older windup mechanisms.  Many a Telechron or Hammond or other branded synchronous motor driven electric clock was cleaned and lubed as a matter of maintenance routine and placed right back into service again.
KB3ZZP
« Reply #9 on: January 22, 2013, 01:01:27 PM »
The clock may well be salvageable.  If I can tract down a crystal from the info. above, I'll be back in business.  Thanks.
W9GB
« Reply #10 on: January 22, 2013, 01:47:56 PM »
For additional information on Telchron clocks, this is good web site:
http://telechron.net/main.htm
Good discussion of replacement Telechron rotors (B, H, S), and where to get them:
http://telechron.net/features/faq.html
His new e-mail was at QRZ
W8VHF
ELMER C SPENCER
6144 W Dewey Rd
Ludington, MI 49431
w8vhf2 at gmail dot com
« Last Edit: January 22, 2013, 01:55:25 PM by W9GB » Logged
AC5UP
« Reply #11 on: January 22, 2013, 05:20:31 PM »
GE Telechron clocks are fairly common in thrift shops and they used the same motor assembly in plenty of them... So maybe a couple of bucks for an older analog GE clock radio can become a rebuild kit. As for a quartz clock movement with matching hands, you can find plenty of those in thrift shops as well. Usually for a buck or two, just keep both eyes open and think like you're at a swapmeet.
With a little luck you could use a pair of silicon diodes (1N4001 type) in series as a 1.4 volt Zener substitute and power it from a junkbox transformer so the clock is independent of the power switch.
What do we want?  TIME TRAVEL!
When do we want it?  THAT'S IRRELEVANT!
