Author Topic: rg8u vs lmr400  (Read 770 times)
KC9PNN
« on: January 29, 2013, 03:05:52 PM »
which coax is the best going to put a 2meter beam up at 100ft thanks  Grin
tim kc9pnn
DXZEPP
« Reply #1 on: January 29, 2013, 03:23:56 PM »
LMR400
KC9NVP
« Reply #2 on: January 29, 2013, 04:00:40 PM »
KC9PNN, do you plan to rotate your beam?  If so, LM400 may be ok up to the point just below the rotor and change over to RG213 or RG8X for flexibility as the beam is rotated.  LM400 is stiff and does not bend very well.
David
« Reply #3 on: January 29, 2013, 04:08:52 PM »
The difference in 100' of coax is about 1dB.  Does that make a difference in your operation?
« Reply #4 on: January 29, 2013, 05:14:17 PM »
Very true, when you look at the difference between them instead of total loss you can see more clearly how little the difference is at times.
N4CR
« Reply #5 on: January 29, 2013, 07:32:35 PM »
Times also makes LMR-400 UltraFlex which is excellent for going around a rotor. Same specs as LMR-400 with a stranded center conductor.
73 de N4CR, Phil
KA7NIQ
« Reply #6 on: January 30, 2013, 07:37:59 AM »
Thanks for the Info! I was unaware that LMR 400 was made with a stranded center conductor. Who has the good deals on it ?
W9GB
« Reply #7 on: January 30, 2013, 06:03:01 PM »
Quote from: KA7NIQ
The UltraFlex LMR-400 will be 30 to 40% higher than standard LMR-400.
Davis RF - Low-Loss Braided Coaxes (Times, Andrew, etc.)
The 400 size starts around 85 cents/foot.
http://www.davisrf.com/lmr.php
I actually prefer the Marine grade coaxial cables (40+ years discovery process)
http://www.davisrf.com/rgcoax.php
RG-213, 50 ohm, stranded Mil C-17, non-contaminated jacket
C213     $0.721. $0.619. $0.577. $0.517
« Last Edit: January 30, 2013, 06:11:34 PM by W9GB » Logged
AA4HA
« Reply #8 on: January 31, 2013, 08:26:18 AM »
I am not in the business of selling it to hams (commercial only) but here are the prices we pay for it;
Cable LMR-400 Standard Outdoor Cable Per Foot  : 0.83
Cable LMR-400 Ultraflex Per Foot : 1.00
Cable LMR-400 DB Watertight Per Foot : 0.90
You should be able to find something comparable from suppliers. It looks like the $0.83 price is very similar to what you can get from a distributor of amateur radio feedline. I would think that UltraFlex or Watertight (gel flooded, direct burial rated) should be along the same lines.
As you can imagine we would mark it up and usually sell thousands of feet on spools. Freight is a killer.
« Last Edit: January 31, 2013, 08:30:01 AM by AA4HA » Logged
Ms. Tisha Hayes, AA4HA
Lookout Mountain, Alabama
