Author Topic: MFJ-752 Signal Enhancer Audio Filter  (Read 3266 times)
KD0EXQ
« on: January 30, 2013, 05:07:36 AM »
Bought one of these off the online auction site awhile back (yeah, I know).  Anyway, after looking through the manual online, getting the proper power supply (wall wart) and the correct radio to device cable, I tried it out.  No audio at all.  Don't have any "test" equipment, other than a multimeter.  Any suggestions to see if this is functional?  If not, I'll consider it DOA and learn from the experience.
KA4POL
« Reply #1 on: January 30, 2013, 06:21:19 AM »
Audio can be checked easily. Connect a speaker and touch the signal line with a screwdriver holding the metal in your hand. You should hear the hum. As you got the manual, there is a schematic which identifies parts and voltages. Check the voltages. Worst case you got to change one of the 747s or the LM380.
KA4POL
« Reply #2 on: February 02, 2013, 11:03:16 PM »
Any results from measuring voltages?
KD0EXQ
« Reply #3 on: February 04, 2013, 01:08:13 PM »
KA4POL:   REALLY appreciate you checking back up on this.  The manual online was for a newer version and did not have the info suggested.  Sent an email to MFJ to see if they could send me the schematic.
KA4POL
« Reply #4 on: February 04, 2013, 10:01:59 PM »
Just curious, this one should be really easy.
