Author Topic: Station Setup  (Read 1771 times)
N8EUI
« on: February 04, 2013, 12:15:45 PM »
Hello everyone,
I've added some additional equipment to my station.  I'm also rearranging my station setup and I have a question:  Given my transceiver, amp, wattmeter, spectrum analyzer and antenna tuner, in what order do I patch them in?
Tom, N8EUI
KD8GEH
« Reply #1 on: February 04, 2013, 01:00:33 PM »
Congrats onyour upgrade Tom.
IMO: Rig, amp, tuner, wattmeter(with SWR bridge? or does ur tuner have?) analyzer.
73, Dave
« Reply #2 on: February 04, 2013, 01:05:59 PM »
Quote from: KD8GEH
No, the wattmeter/SWR meter goes on the INPUT to the tuner.  You probably want
the analyzer there also.
Rig, amp, analyzer, watt/SWR meter, tuner.
KD8GEH
« Reply #3 on: February 04, 2013, 01:40:33 PM »
Thanks Dale your correct.  I stand corrected..dont know what I was thinking.  Huh
KQ6Q
« Reply #4 on: February 04, 2013, 10:14:23 PM »
I'd recommend using a coax switch with very high isolation (unused connection grounded), and set it so the Analyzer can be connected directly to the antenna, or the antenna can be connected to the tuner, SWR/wattmeter, amp, rig setup.
If I were using an analyzer, it would be outdoors, connected by the shortest coax to the antenna, so I could make adjustments to the antenna without having to use the rig, just look at the analyzer right there near the antenna.
KD8GEH
« Reply #5 on: February 05, 2013, 02:49:37 AM »
Spectrum analyzer, not antenna analyzer.   Cheesy
N8EUI
« Reply #6 on: February 05, 2013, 06:37:52 AM »
Thanks all for the replies.
Tom, N8EUI
« Reply #7 on: February 05, 2013, 02:31:45 PM »
How do you transmit through a spectrum analyzer?
I've never seen anything like that.
« Reply #8 on: February 05, 2013, 02:45:08 PM »
Normally the spectrum analyzer would be connected by a special "T" type coupling or tap. The tap goes directly after the amplifier. It has a direct connection along the coax line with some amount of attenuation in the coupling to the analyzer.
Personally, I'd never leave a spectrum analyzer permanently in line. With a normal SSB signal you'd have to have a whole lot of distortion in order to see it on an analyzer. Normally those types of tests are run with a dummy load and using a two-tone generator to modulate the transmitter. A spectrum analyzer is better suited to the "test bench" than it is to monitoring an active transmitter.
