Author Topic: Wiring Shure 450 series ii microphone to Drake TR7A  (Read 329 times)
KEVIN1218
« on: February 04, 2013, 07:17:34 PM »
Could use some help......Please advise what color leads from the mic
go to each corresponding pin on the (4) pin connector. I will then solder.
The Shure has a Red, White, Black, Green, & a ground wire.
Drake TR7 is a (4) pin mic connector - Pin 1 is low level audio,
Pin 2 is TX PTT, Pin 3 is ground, & Pin 4 is High level audio.
Drake requires a high impedance mic, I will set the Shure
selection switch so it is in the Hi Z mode.
Thank you in advance for any assistance,
Kevin
W9GB
« Reply #1 on: February 04, 2013, 08:25:11 PM »
DOWNLOAD the Shure 450 Series II - User Guide
http://www.shure.com/americas/products/microphones/other/450-series-ii-voice-communication-microphone
Connect the dots and solder on the connector.
http://55d5340a043a828856e1-f62de27af599bb6703e11b472beadbcc.r28.cf2.rackcdn.com/user_guide/upload/405/us_pro_450seriesii_ug.pdf
Amateur Radio transceivers use UNBALANCED Audio inputs.
KEVIN1218
« Reply #2 on: February 24, 2013, 06:59:11 PM »
Hello everyone,
I still need help, please....I wired the Shure 450 series II mic's Green wire to Pin #1 of the Drake TR7A.
White wire to Pin #2
Ground wire to Pin #3
Pin #4 is empty
Unused mic wires are the Black & Red.
The PTT switch does not activate Transceiver, nothing.
Did I fumble on the wiring?
73's
Kevin
