Author Topic: AL80B VS AL811HD  (Read 943 times)
WB4YAL
« on: February 05, 2013, 12:44:57 PM »
I am getting ready to buy a new amplifier and I wanted to get some opinions/advice from some hams here. I am planning to spend around $1300 and in this price range I have identified the AL 80B and the Al 811HD as possible purchases. I would like to know from users here, " how you would rate each one and which you would recommend." I have only 120 volts to power an amp but the service can handle 20 amps. With this in mind, what would YOU recommend.
Thank you, WB4YAL John.
WB3BEL
« Reply #1 on: February 05, 2013, 12:57:00 PM »
No brainer...
The AL80B is a way better amp.  More reliable tube, easier to tune.
N3JBH
« Reply #2 on: February 05, 2013, 01:01:14 PM »
No brainer...
I agree 100% Even though i have a 811H amp... I rather now have the AL80B amp
KG6YV
« Reply #3 on: February 05, 2013, 01:38:56 PM »
I used an AL80 amplifier on 120VAC lines and it worked fine.
I wouldn't hesitate to buy one over an amplifier with 4 ea 811A's.  Four 811's have a total of 240W plate dissipation, the AL80B has 500W plate dissipation.  You can't hurt a 3-500Z but you can certainly over drive or otherwise get into trouble with 4 811's.  The Al80B will run all day/night at 700-800W output.
This contest isn't even close to me...
Greg
« Reply #4 on: February 05, 2013, 02:18:40 PM »
I think the 80B is a better deal also.
It also includes a built-in front-panel PEP watt/SWR meter the 811HD doesn't have, and that alone is worth about $150.  Bigger power supply, too.  And still "desktop" and "quiet."
WB4YAL
« Reply #5 on: February 05, 2013, 02:36:00 PM »
Well Guys, I thank you for your comments.  I am going to look for an AL80B at the Orlando Hamfest Saturday.
N4OI
« Reply #6 on: February 06, 2013, 04:12:58 AM »
If you are into CW at all, I suggest the AL-80BQ -- with the QSK option installed.  It makes very quiet power without all the relay clacking....  You can add the QSK-5PC card kit  later, but the installation will be challenging if you are not an experienced builder.
Regardless -- get the AL-80B(Q)!
73 ES GOD BLESS U ES URS DE KEN N4OI  Grin
N3QE
« Reply #7 on: February 06, 2013, 06:56:18 AM »
I got a used AL-811H for $400 and am very very happy with the value. Several thousand contest QSO's (recent 160 contests, also the RTTY RU contest) on it just in the past two months. I also operated N3A special event station using it, and also some new DXCC's on both low and high bands.
If I had $1350 in the budget I would've gone with a 3-500Z amp, for sure. I also get to use (at various contest stations) setups with 8877 and other ceramic tube amps at substantially higher street prices. Unlike some others I can't really justify that. Hmm... I thought all hams were notorious for being cheapskates :-)
Others tell you that QSK is important, and I agree, so I do an end-run around the extra cost of a QSK-capable amp, by using a separate receive antenna on 160 (which I would want to do anyway even if I was barefoot). Again, cheapskate.
Shortly after I got the AL-811H and was in a few 160 contests, a local big gun noticed my activities and DX I was working in the tests, and gave me an unsolicited comment that I am now a "second tier" contest station on the bands. Wow, $400 bought my way into the second tier. Not bad, when I know that several of the "first tier" multi-multi stations in the area have what must be $100K worth of equipment.
« Last Edit: February 06, 2013, 07:11:14 AM by N3QE » Logged
