Author Topic: Smart looking new receiver  (Read 8465 times)
KB8VIV
« on: February 05, 2013, 12:58:22 PM »
Intrigued.
http://www.commradio.com/
kb8viv
K0OD
« Reply #1 on: February 05, 2013, 02:09:44 PM »
So who in the heck is Don Moore N0HDX?
Let's see:
"It draws on my experience as a kid building Knight Kits, from my paper route earnings through currently owning a classic Drake 2B and a Zenith Transoceanic; my benchmarks for enjoyable, high quality short wave listening. "
Then he adds an hefty aluminum knob. And Voila, a cutting edge SDR radio!
From his Eham bio:
" I now develop commercial grade, aviation (VHF) transceivers and plan to intorduce [sic] a SSB rig hopefully in 2003/2004.
73, N0HDX, Don"
Anyone know this guy or anything about his background? Has a general class license apparently.
Here's some discussion on an SWL site:
http://swling.com/blog/2013/01/commradio-is-introducing-the-cr-1-a-new-tabletop-shortwave-receiver/
K0OD
« Reply #2 on: February 05, 2013, 03:39:50 PM »
The CR-1 specs are really buried in that website:
"Product Information
Introducing the New CR-1 Communications Receiver
The CR-1 is a small, low-power, ruggedly constructed radio receiver that is finding a niche in the world of SWL’s (short wave listeners) and amateur radio enthusiasts alike.
The CR-1 is a new Software Defined Radio (SDR) from the designers of miniature wideband signal intelligence receivers, developed for special-operations units, and rugged business-jet data-link transceivers.
The CR-1 SDR is independent of a host PC, using embedded digital signal processing technology providing a degree of portability  and performance previously unavailable  to the radio enthusiast.
As one potential customer noted: “It’s an SDR with knobs, keys, and a display!”
Frequency Coverage and Modes:
MW-HF: General Coverage: 500 kHz - 30.000 MHz
    User Configurable Band Key:
        Amateur Band Selections: 160 m – 10 m
        International Broadcast Bands 120 m – 11m
    AM-SSB-CW  auto-mode-selection (based on tuned frequency) with user-override.
    International Broadcasting: auto-select  AM - 5 kHz steps - cursor override
    Auto-Filter Width select with override: AM: 6 and 7.5 kHz kHz/SSB: 2.6 kHz/CW: 1 kHz
    Tuning Resolution (cursor control): 1 MHz  / 100 -10 - 1 kHz  / 100  - 10 Hz
VHF-UHF General Frequency Coverage:
    VHF: Continuous Coverage:  64.0  - 225.0 MHz
    UHF: Continuous Coverage: 437.0 – 468.0 MHz
    Automatic standard frequency steps for each band
    Cursor Controlled (override) Tuning Resolution : 1 MHz / 100 - 10 - 1 kHz
VHF-UHF Band Plan:
    Aircraft Band: 108.000 - 136.975 MHz, AM auto-select -25 kHz channel steps
    Amateur: 2 m, 1.25 m, 70 cm (upper portion starting @ 437.0 MHz); with user selectable standard frequency steps.  NBFM mode default with SSB-CW mode selects.
        Note 6 m (54 MHz) is not available.
    Marine & NOAA Weather Radio
    Public Service: 137.0 - 225.0: 12.5 and 25 kHz steps. NBFM default.
    FRS-GMRS 462 – 467 MHz , NBFM - 25 kHz Steps
Receiver Architecture
    HF: Dual conversion (VHF-UHF: single conversion) with low-IF , I-Q digital sampling, 32-bit DSP with digital audio CODEC
    DSP demodulation algorithms: DSB-AM, SSB, CW, WBFM, NBFM
    DSP scalable, fixed bandwidth channel filtering
Audio System –  (Digital CODEC)
    Speaker Driver: 0.8 W into 8 Ohm load
    Internal 2.5” diameter, Mylar communications grade speaker
    External monaural speaker jack (3.5 mm stereo jack - back panel)
    Headset Driver: 40 mW into 16 Ohms. (3.5 mm stereo jack - front panel)
Antenna Inputs
    MW-HF Port: 1000 Ohm – 3.5 mm jack (auto-detection)
    MW-HF Port: 50 Ohm – BNC (female)
    VHF-UHF Port: 50 Ohm – BNC (female)
Display
    64 x 128 OLED Display with EMI-filtered lens
    Readable outdoors  and manually dimmable
Power Inputs
    USB and 6-18 VDC – 2.1 mm diameter center pin (positive) jack
Power Consumption
    < 1.0 Watt
USB
    Mini-B –USB 2.0 Jack (powered):  Downloadable software updates from CommRadio Website
Mechanical
    Overall Size: 5.64” W x 2.43” H x 6.10” D (including knobs, jacks , feet)
    Weight: 1 lb – 12 oz
    Knobs: Machined Aluminum – Black Anodized
    Front Panel: Machined Aluminum – Powder Coated – Black semi-gloss
    Case: 20 Gauge Steel, Powder Coated – Black Crackle.
ESD Protection:  ESD Diodes: Antenna ports - Power Jacks - USB Port-Keys – Knobs
Hardware Design Limitations:
    The CR-1 is not controllable over USB by CommRadio or third-party software at this time.
    I-Q analog and/or digital IF signals are not ported to the rear-panel or accessible or at a standard sound-card sampling rate.
    Both of these options may be added, provided demonstrated interest
Software Demodulators Not embedded in the CR-1 at this time:
    Mono or Stereo FM broadcast Demodulator
    P25 or Trunk Radio
    D-STAR
    DRM
Always Free: Planned Software Upgrades:
    SW revisions and upgrades (improvements)
    FM broadcast demodulator (US and International)
    European Band Plans:  MW- 9 KHz Frequency Steps
Potential New Software Applications (provided free if they occur, but not guaranteed to all new customers in 2013):
    Spectral Display (across individual bands) – fast detect of band openings
    CW reader ported to display and over USB
    PSK-31 decoder ported to display and over USB.
    Tell us what you want.
Origin & Warranty
    Designed and manufactured in USA
    Limited 1 year warranty on parts – labor – workmanship
Warranty"
KA1BIN
« Reply #3 on: February 06, 2013, 02:23:02 AM »
Great web site.......
The thing that bothers the heck out of me are a few things,
I don't see any type of FCC Certification on the unit or in the specs page, As far as I remember "any radiator (that which emits radio energy),
whether or not intentional, must be licensed unless it meets 47 CFR 15 or is otherwise exempted by the FCC."
Last I remembered any "computerized type item", especially if it contains a microprocessor, has the potential to emit RF.
It is also interesting that the web site is practically bare...
at the top is:
303-279-3671, Home, My Account Sign in or Create an account, View Cart
I also don't understand why "Product Info" button has to take you to offsite to a third party
called...https://store-ckohqsq.mybigcommerce.com/cr-1-communications-receiver/
The product specs, warranty, and other information can't appear on the main web site?
Just my opinion.
I know that my company would not be able to sell an item like this without
a FCC certification. I had to have a FCC Type A certification back in the late 1980's
just to make and sell a secondary programmable keyboard for IBM PCs. A simple
keyboard with a Motorola N8042AH 8-Bit MCU was all it took to require certification.
Steve - KA1SMC (formerly KA1BIN).
K0OD
« Reply #4 on: February 06, 2013, 05:31:32 AM »
A WB2KTG serves as something of a surrogate for the maker online. They're friends, WB2KTG says. Here he shows nice photos of the radio's innards:
http://forums.radioreference.com/software-defined-radio/256366-new-sdr-commradio-cr-1-a-4.html
http://forums.radioreference.com/software-defined-radio/256366-new-sdr-commradio-cr-1-a-3.html
Then WB2KTG claims the CR-1 can hear a 40 meter CW signal easily that could not even be detected on a ICOM-R20 handheld receiver and active antenna (an unusual setup for a comparison).
Thought this statement was funny: "There must be a contest going on 'cause this one guy has been pounding at about 20 WPM for the past hour or so. So far I'm impressed with the CR-1!"
Wow, 20 WPM! Must be a contest. Apparently WB2KTG isn't much of a CW op and "so far" he's impressed with the CR-1 based on listening for one station on 40 meters, of all bands! Not mentioned is that the CR-1 has only one bandwidth on CW, 1 kHz.
I agree with this posted comment: "It would be nice to find out more, to be certain. I'm a little taken aback by the fact that the guy is looking for people to get on the waiting list for purchase, while he comes up way short in an explanation of exactly WHAT is being purchased and how it's going to work."
As for N0HDX's credentials, I'm still finding almost nothing. Judging by call lookups, he doesn't appear to be active on the air.
KB8VIV
« Reply #5 on: February 06, 2013, 05:45:15 AM »
Apparently, this is his day job:
http://www.aerostream.com/index.html
There is a picture of the cr-1 which shows a spectrum display on the oled screen (on the above website).  On the video's that are on youtube, I don't even see an s-meter.  I'm still interested to see how it performs out in the wild.
kb8viv
AUSSIE
« Reply #6 on: February 06, 2013, 10:48:25 AM »
Hi well the date for delivery of the CR-1 has been changed from Febuary 15th to the 22nd.The youtube video shows he is listenning to radio stations with lots of power which most people can pick up with any radio when it comes to emails takes a long time to get a reply and if you want to make a name for youself in the receiver market you have to compete with aor,alinco,icom,ten tec and no overseas sales available till may.I
am ordering mine this week it will be intresting to see how it compares to other receivers..
Regards Lino..
MY SHACK:
ALINCO DX-R8 (2)
AOR-3030,AOR-7030
DRAKE-R8,DRAKE-SW2
GRUNDIG SATELLIT-750
ICOMR71A,ICOM-R75 (2),
JRC NRD-535,JRC NRD-545DSP (2)
KENWOOD-R5000
LOWE-HF235
PALSTAR-R30A
RACAL-6790
RFSPACE SDR-IQ (2)
TEN TEC-320D,TEN-TEC-340,TEN TEC-350D
WATKINS JOHNSON-HF1000A
KB8VIV
« Reply #7 on: February 07, 2013, 04:07:03 AM »
Hi Aussie, I can't wait to hear your thoughts on it.
Kb8viv
K0OD
« Reply #8 on: February 07, 2013, 06:18:01 AM »
From the few photos and one video, the CR-1 doesn't currently seem have an S-meter, but it may have a rudimentary panadaptor which can be seen in this picture, but none of the others. http://www.aerostream.com/images/cr1.jpg
Aussie: "when it comes to emails takes a long time to get a reply"
Aussie:  "I am ordering mine this week."
AUSSIE
« Reply #9 on: February 07, 2013, 04:40:49 PM »
I have to wait till may to order mine which is dissapointing..
Regards Lino..
K5TED
« Reply #10 on: February 16, 2013, 08:16:29 PM »
Looks like the guy, even handicapped by holding only a General Class Amateur Radio license  Roll Eyes , has some achievements of note in the realm of commercial radio products.
Nice form factor. Good specs on paper.
SWL535
« Reply #11 on: February 17, 2013, 10:07:06 AM »
Fenu had one for evaluation at a SWL DX camp.
Pictures of the circuit board.
Chrome translates...
http://www.fenu-radio.ch/
Ken
White Rock, BC Canada
K5TED
« Reply #12 on: February 17, 2013, 03:39:25 PM »
For the price of $650, or even $500, lacking a computer interface or I/Q port makes it a bit of a boutique radio.
Still, nice looking rig.
K0OD
« Reply #13 on: February 17, 2013, 04:12:08 PM »
I only found what he posted about himself on his two sites and even that wasn't much. Noteworthy was what wasn't posted, such as his educational background and where he has worked since becoming a ham decades ago.
What "achievements of note" are you referring to?
PBPP
« Reply #14 on: February 19, 2013, 06:31:33 AM »
Looks like junk to me.... just like his previous offerings.
~ Mitch ~
