Author Topic: Isn't this illegal???  (Read 2787 times)
M0HCN
« Reply #15 on: February 10, 2013, 05:56:36 AM »
Sure, protocols are things like levels, time durations, etc.  A protocol isn't at issue here.
Actually iff the protocol documentation is complete it is sufficient to implement Pactor 3, you do not need their source code (Just a C compiler, the protocol and some time to pen your own implementation).
Pactor 3 is documented in ITU-R 1798, which may be more useful then the SCS technical description.
It is precisely the source code to produce a pactor 3 interchange that is at issue, and makes it an intentionally exclusive mode.  A mode only available to those willing to "pay SCS' price."
Not really, it is also available to any ham willing to turn the protocol documentation into either software or hardware. Of course if the documentation is incomplete or if the real signals do not follow the documentation (quite possible, writing correct documentation is hard) then you are into the field known as 'reversing' and that really needs access to the hardware to generate known signals.
You do not need to have code identical to SCSs to have interoperability, you jut need to produce something on air that follows the protocol, after all we have probably got a dozen or so implementations of the TCP/IP protocols out there and they all talk to each other just fine.
Having a reference implementation is very helpful, no doubt, but it is not required.
And, just how would I do that?  Buy an SCS black box, then try x to the nth combinations of the protocol data to determine ASCI characters and punctuation?
Well you could do that, but it sounds a little painful, I would start with the ITU documentation and something like gnuradio (Provides convenient building blocks), and actually the interleaving and coding is described in the protocol, as is the higher level packetisation, so once you have the output from the viterbi decoder working the rest looks fairly straightforward.
73 Dan.
« Last Edit: February 10, 2013, 06:10:00 AM by M0HCN » Logged
KG4RUL
« Reply #16 on: February 10, 2013, 06:15:13 AM »
73 Dan.
Having been a developer of embedded software systems, I totally concur with Dan's comments.
W6EM
« Reply #17 on: February 10, 2013, 07:03:46 AM »
73 Dan.
Thanks, Dan, for the lesson.  Apparently, what is necessary to effect it is too difficult for anyone else to do, thus far.  Then again, maybe there isn't such a big market for it.
M0HCN
« Reply #18 on: February 10, 2013, 08:17:57 AM »
Small market, and those who do this stuff for fun usually have half a dozen or so projects of more interest to them on the go.
Fact is, that license is probably cheap enough to make doing a clean implementation as a commercial effort a waste of time and that just leaves the open source crowd who all have projects of their own on the go.
None the less the spec is out there if you chose to implement it.
This differs from something like say adding an AES3 layer to a PSK mode and only distributing the key to your friends (Which would definitely be illegal on the ham bands, even if I published the source code), or using something like the OPs lookup table with a private one that was not available on the web, same for one time pads and such.
Regards, Dan.
N4ZAW
« Reply #19 on: February 11, 2013, 10:40:38 AM »
At the point that it would be actually TRANSMITTED, yes. Until then, the FCC you,me the pope can do nothing to prevent them.
At the point that they would use this "code", the point of legality becomes moot because anarchy would be the government du jour, or a government which would go against the constitutional and God-given freedoms to do intervene. And yes, I realize we are already there with the current regime. But that wasn't the question. You could try to get your operatives on the inside to learn the code first anyhow. Is it against the law to formulate a code? No. It's against the law to use it in communications.
I think I'm going to check into this further. I might want to learn it now while I have the chance.
KU7PDX
« Reply #20 on: February 11, 2013, 02:07:56 PM »
According to a website I just viewed (http://www.catastrophenetwork.org/?p=1027#comment-8562) - they claim to have "developed" a "Standardized Coded Matrix for Prepper Communications". Now as I read the FCC Rules - it states:
Sec. 97.113  Prohibited transmissions.
    (a) No amateur station shall transmit:
    (4) ... messages in codes or ciphers intended to obscure the
meaning thereof, except as otherwise provided herein; ....
But these guys have made available their "Secret" code matrix for PDF download on their website.
I posted a reply to their article on their page quoting the above FCC Rules but it is "Awaiting Moderation".
Any thoughts from you guys???
73 de W8BNL - Tom
No reason why this wouldn't be allowed. They've developed and published a phone communications protocol that the public has access to. The document even states "©2012 Catastrophe Network, Please Distribute Freely."
Nothing secret, and since it isn't secret, it doesn't obscure any meaning.
Chris - KU7PDX
W6EM
« Reply #21 on: February 12, 2013, 04:17:13 PM »
......., or a government which would go against the constitutional and God-given freedoms to do intervene. And yes, I realize we are already there with the current regime. .........
  Domestic spying/evesdropping (the Patriot Act) was implemented during the Bush Administration.
KB2WIG
« Reply #22 on: February 12, 2013, 04:37:19 PM »
[/quote]  Domestic spying/evesdropping (the Patriot Act) was implemented during the Bush Administration.
[/quote]
Its been around a lot longer than the Bush Administration. Check out the following....
Olmstead v. United States, 277 U.S. 438 (1928 ) and the Omnibus Crime Control and Safe Streets Act of 1968.
WTA,
klc
KB4QAA
« Reply #23 on: February 12, 2013, 05:40:44 PM »
How about coming back to earth and keeping the discussion on real life terms and not dooms day fantasies, fellows?   Jeez.
BUFFOON
« Reply #24 on: February 15, 2013, 06:41:40 PM »
And much of it was "re-upped" during the Obama administration.
So what?
N7KFD
« Reply #25 on: February 20, 2013, 05:20:28 AM »
Why not use pig latin?
