Author Topic: tone encoder mod question  (Read 2374 times)
K5BDJ
« on: February 10, 2013, 02:36:19 PM »
I have an ICOM IC-25A.
If I add the SS-64 tone enocder to it, will it now work most repeaters?
Will the SS-64 fit inside OK?
Is it wiring friendly to hams?
KA4POL
« Reply #1 on: February 10, 2013, 10:10:25 PM »
See http://www.eham.net/ehamforum/smf/index.php?topic=64072.0
K5BDJ
« Reply #2 on: February 10, 2013, 10:45:55 PM »
Pretty well answers what I was asking.   Thanks.
The only thing I picked up on was that one guy said it was a PITA to change tones.
Does this mean you can run through a bunch -- or, do you have to go in each time you want a different tone and do something to select it?
KA4POL
« Reply #3 on: February 11, 2013, 12:30:25 AM »
Each tone requires a DIP switch setting. So I would never install it inside if I can expect switching around. I am no gynecologist  Grin
K5BDJ
« Reply #4 on: February 11, 2013, 04:55:52 AM »
Great.   Thanks for all your help.
WB5ITT
« Reply #5 on: February 22, 2013, 03:19:23 PM »
Com Spec used to make an external switch for their older SS32/TS32 products..it was hex based and would allow you to easily dial up the proper tone ..I put one in a plastic box from Radio Shack with a SS32 and ran the cable into both of my Yaesu FTx27s (a 227 on 2m and a 127RA on 220) so I could easily dial up any PL tones I needed....I donot know if they make a 64 position switch or not..however, the 32 position switch with an extra switch to flip the leading bit (0 on pos 1-32 and 1 on 33-64) would work OR you may be able to find a switch via ebay or google...but it will be a 5 bit 64 position switch....that will be a rare one.
Chris
WB5ITT
K4JJL
« Reply #6 on: February 26, 2013, 08:21:43 AM »
I remember adjusting the tone on my old Kenwood TR-2500 handy scratchy.  You put a diddle stick in the back case and turn a pot until the repeater opened up.  Convenience!
K1CJS
« Reply #7 on: February 28, 2013, 05:01:05 AM »
I went a different way.  Got mini SPST toggle switches from Rat Shack (fifteen years ago, they still had a decent selection) along with an experimenters case.  Mounted that to the IC-25A that I had and had three wires coming out of the rig.  Power, ground and signal in, with the Com-spec tone unit in the experimenters box.  Made sure that the DIP switches were all open, carefully soldered thin wires to each dip switch connection (only one to the common side of them) and had an outside switch for every dip switch and a switch position chart for changing tones.
Sure, it was a bit of a bother to change tones, but it was cheaper than the rotary switch they (Com-spec) sold and was handy.  73!
« Reply #8 on: February 28, 2013, 06:34:26 AM »
For the extra ambitious, make up a diode matrix that connects to the memory switch contacts and map the proper PL to the memory location.
K4JJL
« Reply #9 on: March 01, 2013, 10:05:57 AM »
Heh.  Sounds like a Mastr II ChannelGuard board...
