Author Topic: HF Mobile AutoTune Whip Antenna  (Read 10034 times)
K3VAT
« on: February 15, 2013, 08:37:02 AM »
This antenna advertisement in QST March p23.
It has a memory auto-tuner built into the base of the antenna. Looks like to be a first! Check it out at:
http://www.stealth-tele.com/plugins/custompages/detinf.php?id=373&id_categories=155
73, Rich, K3VAT
PS: I have no connection whatsoever to this company.
« Last Edit: February 15, 2013, 09:14:00 AM by K3VAT » Logged
AC4RD
« Reply #1 on: February 15, 2013, 09:02:03 AM »
No offense, but there is a BIG difference between "is featured in" and a paid advertisement.
K3VAT
« Reply #2 on: February 15, 2013, 09:14:27 AM »
You're correct, I've changed the wording.
W5WSS
« Reply #3 on: February 15, 2013, 10:22:40 AM »
Nice.
The evolution of this design could be in the area of better input power management.
Although 200 watts pep is fine for mobile work. Maybe a little low for base station use.
The Stealthy antenna would most likely be used as a ground mounted vertical by hams if the price is competitive to say the step IR.
Therefore the efforts to upgrade the input power to the antenna would be desirable profitable is a different matter.
The quarter wave family of verticals presents plenty of radiation for excellent long range DX hf work this antenna appears rugged and fully capable of the highest presentation of power into the environment.
My only concern is that we need to see the inside design and at this point it is not known.
KA4NMA
« Reply #4 on: February 15, 2013, 06:21:58 PM »
It looks like a whip with auto tuner.  SGC has something like it.  They have a whip that can be used with an auto tuner.
Randy ka4nma
K3VAT
« Reply #5 on: February 16, 2013, 08:23:26 AM »
Randy ka4nma
Unless I'm mistaken, only SGC's whip antennas are only whip antennas.  They do facilitate mounting to one or more SGC autocouplers.  See: http://sgcworld.com/whipantProductPage.html.  You may be thinking about this: http://sgcworld.com/Publications/Manuals/stealthman.pdf, but there again, there are 2 separate products.
This antenna has the antenna tuner built-in to the antenna's base.  However, what's missing from this new whip antenna's specifications is the range of matching.  I tried looking at their manuals to see what is the impedance matching range of their antennas and unless it is somewhere where I didn't look, it is absent.  I think that this is what also concerns W5WSS - let's see more of the technical information.  Thanks, 73, Rich, K3VAT
« Reply #6 on: February 16, 2013, 08:40:53 AM »
Even the SGC whips (I have one) are more than a simple straight whip. The lower frequency part is a helically loaded copper tape wound around a fiberglass pole to provide a load impedance that is easier for the tuner to match. The higher frequency part is a straight wire run up through the center of the pole.
KCJ9091
« Reply #7 on: February 16, 2013, 09:55:22 AM »
It is made in UAE and the dealers show POR.  Hold on to your wallet.
ALEXST
« Reply #8 on: April 20, 2013, 02:46:53 AM »
Here Stealth 93-series mobile HF antennas inside look http://www.youtube.com/watch?v=c95wjBnat0c
Here example of 9360 antenna operation with Vertex Standard VX-1700 http://www.youtube.com/watch?v=ZJBUthN-4qA
M6GOM
« Reply #9 on: April 20, 2013, 04:07:35 AM »
Its made in the UAE, one of the richest countries in the world per capita and you're saying hold on to your wallet as if it was some cheap chinese junk?
At least they made a video which shows you all about it and them doing abuse tests on the casing. I don't seen Scorpion, Tarheel or any other mobile antenna manufacturer doing that.
« Last Edit: April 20, 2013, 04:12:21 AM by M6GOM » Logged
KC9DRE
« Reply #10 on: April 21, 2013, 11:00:06 PM »
I took this as it was going to a fairly pricey piece of equipment not a knock on the quality.  Kinda like fainting from sticker price shock....
