Author Topic: Read frequency of tuning fork on counter  (Read 1227 times)
KD2E
« on: February 18, 2013, 10:30:50 AM »
Trying to read the frequency of a tuning fork using my counter.
I suspect my dynamic tape recorder microphone just does not have the
output required for the counter to trigger.
So, would you suggest a ceramic or crystal element....or is there a WAY better
method of doing this.....without building a circuit to add to the mix.
Thanks for any suggestions.
....Dave
KB3HG
« Reply #1 on: February 18, 2013, 11:49:49 AM »
A thought,  record the tuning fork on your pc playback through speakers tap speakers for sampling. Heck even you cell phone might record well enough. I'm really thinking that an electret (Wide 30-15,000Hz frequency response) vs condenser (Wide 50-10,000Hz frequency response) crystal or ceramic would be better. wav or mpeg files
Tom Kb3hg
KA4POL
« Reply #2 on: February 18, 2013, 12:23:41 PM »
You can measure very accurate using http://www.qsl.net/dl4yhf/spectra1.html
A laptop microphone is sufficeint. I used it for tuning low frequency generators.
KD0REQ
« Reply #3 on: February 18, 2013, 01:38:28 PM »
or wind a coil around the tuning fork, hook it to the freq counter, strike the fork and hold it to a magnet.  if there is enough wire, you can get enough voltage to feed the counter's chips.
the reverse was used in the 30s for master clock timing in radio.  General Radio had an oven-mounted tuning fork driven with big-boned triodes that output 115 volts at exactly 60 cycles to power clocks.  the triodes ran magnets that vibrated the fork.
this was before Hammond (the organ guy) slyly made the electric grid stable by giving away his then-signature product, the syncronous-motor clock, to power company executives.  they didn't keep good time until the plant operators started hanging on their controls and keeping the speed constant, and the power execs made it happen so they could keep the pretty clocks on their polished desks.
KE3WD
« Reply #4 on: February 18, 2013, 04:05:04 PM »
What counter is involved?  Does it have preselector on it in order to get down into the audio region?
What is the input spec for the counter?  Input Impedance may be 50 ohms and able to load down ANY mic output.
K0JEG
« Reply #5 on: February 19, 2013, 03:19:01 PM »
Also the basic theory of operation for an Accutron watch. Later adapted by Seiko for the Pulsar quartz watch that is used by nearly everyone today.
KD2E
« Reply #6 on: February 19, 2013, 03:27:16 PM »
the "motor" theory is cool, but might be mechanically difficult.
Anything touching the tuning fork....even lightly...stops it from
vibrating instantly.
TANAKASAN
« Reply #7 on: February 20, 2013, 01:04:32 AM »
Interesting problem, I played around with this until I got a reasonable solution:
1) As others have suggested you need to boost the output of your microphone as the output will be too low to trigger the counter. Any audio amp should do.
2) Place the microphone on a hard surface.
3) Strike the tuning fork then place it on top of the microphone.
Tanakasan
« Reply #8 on: February 20, 2013, 05:44:39 AM »
....or is there a WAY better method of doing this.....
....Dave
Use your computer sound card with a microphone and one of the free audio spectrum analyzer programs.
N7EKU
« Reply #9 on: March 13, 2013, 03:47:52 PM »
Way better than all of the above!
Simply use a sound generator program on your pc to play a tone and vary it until it zero beats with the tuning fork.
Mark.
