Hi All!
Putting together a staition after a 20 year layoff.
Picked up the abouve tuner to go with a FT-747GX given to me. I have the interface cable all setup and things are working but I wanted to pick someone's brain about the SWR/PO meter switch if you have one... Mine doesn't lock in the down position (for SWR) like it's neighbor the 15/150 power switch and I wanted to verify whether it should or should not...
By reading the manual I believe it should...
Thanks in advance if you have one!
