Author Topic: Engine noise only on HF???  (Read 7852 times)
KC7DCW
« Reply #15 on: February 28, 2013, 09:47:07 AM »
all 1/4 stainless steel hardware. I used a factory bolt that connects the flywheel cover to the tranny. Kept the factory bolt and used a external stainless steel washer bewteen the strap and the tranny.
W4KA
« Reply #16 on: March 01, 2013, 04:40:12 AM »
I don't know the milage of your truck but if 40,000 or more be sure plug wires are O.K..  This is what caused my noise.  Also follow up on the other fine advice given.  73, David  W4KA
N5FPO
« Reply #17 on: March 02, 2013, 11:28:01 PM »
Amen on the noisy injectors, EFI systems on Fords have long been a source of electrical noise, but you should investigate whether the noise is coming through the antenna or the power cable first, might save you some headaches to know. My guess is the antenna since you're not hearing noise on VHF/UHF.
