Author Topic: AM Broadcast Filter Needed  (Read 3453 times)
ND9B
« on: February 25, 2013, 09:12:38 PM »
I live close to an AM station on 1350 KHz. My Kenwood TS-570 can handle it WITH the attenuator turned on, but my old Kenwood R-599 is severely overloaded even with the RF gain turned down.  I think a notch filter tuned to 1350 KHz would be just what I need. Are there any commercially available units that would fit the bill?
Bobby Dipole ND9B
TANAKASAN
« Reply #1 on: February 26, 2013, 04:34:25 AM »
Grab a copy of July/August 2008 QEX and you'll find an article by Wes Hayward W7ZOI on building crystal notch filters. 1.35 MHz crystals will have to be ordered but with one of these filters plus some decent screened cables you should be sorted.
Tanakasan
KE3WD
« Reply #2 on: February 26, 2013, 05:54:00 AM »
http://dlwc.com/
http://www.universal-radio.com/catalog/filters/4426.html
AD5X
« Reply #3 on: February 26, 2013, 02:02:07 PM »
I don't know how much help your receiver needs, but here are a couple of choices that work very well:
www.arraysolutions.com/Products/BCB%20RF%20Filters.htm
Phil - AD5X
« Reply #4 on: February 27, 2013, 03:09:44 AM »
With just one BC station, a 365 pF variable cap from an old BC radio, and coil will make a fine wavetrap: just need a small metal box to put it in and a couple of connectors. Depending how the radio is configured, you may not even need any switching on transmit.
ND9B
« Reply #5 on: March 13, 2013, 06:43:41 PM »
Problem solved Smiley A crude homemade notch filter was all my Kenwood R599 receiver needed. For my transceiver I bought a Morgan Manufacturing model M-402X BCB filter. You can transmit through this filter without any TX/RX switching. Works great.
Bobby Dipole ND9B
