Author Topic: FT2400 backlight out  (Read 1158 times)
WT8E
« on: March 05, 2013, 08:48:44 AM »
Somewhere I read about replacing the backlite lamps with a resistor and a LED. I have searched here but no luck. My meter is completely out, any leads to where I can find that information will be appreciated.
N4NYY
« Reply #1 on: March 05, 2013, 09:51:22 AM »
http://gloucestercountyarc.weebly.com/the-elmers-shack.html
W9GB
« Reply #2 on: March 05, 2013, 11:02:46 AM »
Yaesu FT-2400H Owner's Manual
http://home.comcast.net/~jetaylor433/ft2400h.pdf
Yaesu FT-2400H Service Manual
http://home.comcast.net/~aa4df02/ft2400tm.htm
Yaesu FT-2400 Schematic Diagrams
http://www.ko4bb.com/manuals/index.php?dir=Yaesu/Yaesu_-_FT-2400
Packet Modification
http://www.repeater-builder.com/yaesu-vertex-standard/pdfs/yaesu-ft-2400h-packet-mod.pdf
Contact Yaesu USA Parts for your replacement parts order.
Yaesu USA
6125 Phyllis Drive
Cypress, CA 90630 USA
1-714-827-7600
For Technical Support or Customer Service call,
(714)827-7600 between 8AM – 5PM PST
For Parts Department call (714)827-7600 between 8AM – 5PM PST.
The FT-2400H uses FOUR Lamps and FOUR Lamp holders found on the
CNTL UNIT printed circuit board (front panel).
Q1000065 LAMP : DIAL LIGHT 9 VOLT (PL2001-PL2004 in schematic and PCB X-Ray layout)
R3139660 LAMP HOLDER
NEED A NEW LITHIUM COIN CELL ??   That is BT2001, CR2016-TS1 (solder tab)
That Yaesu Part number:  Q9000552 Lithium Battery
Digi-Key P222-ND / Panasonic CR-2016/F2N (over 53,000 in stock !!) at $ 1.08 each.
The OLD Sanyo suffix for this solder tab was: 1F2, as CR2016-1F2
http://www.panasonic.com/industrial/includes/pdf/CR-2016-F2N%20(CR2016-1F2E).PDF
Panasonic CR and BR lithium coin cells
http://www.panasonic.com/industrial/batteries-oem/oem/primary-coin-cylindrical/br-cr.aspx
These are related Yaesu part numbers;
Q1000086 LAMP 10V/60MA CLEAR CAP (2400/5100) $ 1.25
Q1000087 LAMP 10V/60MA ORANGE CAP $ 1.25
Q1000088 LAMP 10V/ 60MA RED CAP (2500) $ 1.25
« Last Edit: March 05, 2013, 11:39:09 AM by W9GB » Logged
