Author Topic: Mysterious receive boost  (Read 3868 times)
ND9B
« on: March 07, 2013, 07:18:09 PM »
The SWR on my HF antenna recently went to hell in a hand basket. It turned out to be a corroded SO239 barrel connector splicing two lengths of coax together outside. After replacing the connector, I noticed the local AM broadcast station (that I'm very close to) went from +60 over 9 to +80 over 9. (Now I need a BCB filter, but that's a different topic.) After making some contacts, I believe reception in general is stronger.
Now the corrosion on the barrel connector probably didn't happen over night. Is it possible that it was affecting RX but not TX for a period of several years? And, then finally got bad enough to affect TX?
Bobby Dipole ND9B
« Reply #1 on: March 07, 2013, 08:00:13 PM »
Very possible.  In the RX mode the signal is in the microvolt range and a little resistance goes a long way.  In the TX mode the high RF voltage would probably blow through.
WA7RBC
« Reply #2 on: March 09, 2013, 10:06:37 PM »
It would have been interesting to measure the SWR with a (relatively) low-power analyzer.
73,  Ron.
KE3WD
« Reply #3 on: March 10, 2013, 04:03:00 PM »
The dissimilar metal junctions in the barrel connector, aggravated by corrosion, can act like diodes...
K1DA
« Reply #4 on: April 17, 2013, 08:58:04 AM »
I thought voltage drop was related to current.
« Reply #5 on: April 17, 2013, 09:05:58 AM »
It does but basic ohm's law contains 3 elements.....Voltage, Current and Resistance.
KB5ZSM
« Reply #6 on: April 17, 2013, 06:11:32 PM »
Another thought is the transmit power may have been arcing across or the connection may have been acting like a capacitor.
