We just installed FLDIGI into a iMAC G5 and did the complete configuration... just like it is on another iMac we have here. The problem I am encountering is that when I go to save the Configuration Files, I do not see the normal file save panel with the options for selecting where one wishes to save the file. I took a look at the files area for FLDIGI and see the file ( fldigi_def.xml ) which according to the FLDIGI Help Site... is the correct name of the configuration file. We do not know why the prompts are not showing after the save command and the files are not being saved. When we re-boot the Computer and open FLDIGI, its the default settings and not my changes.
It should have been saved in ~/.fldigi which is a hidden directory in your home directory.
Do you have the finder set to reveal hidden files/directories on the iMac where it is not visible?
