Author Topic: Noisy roller inductor  (Read 3614 times)
W5KG
« on: March 15, 2013, 07:29:51 AM »
I build a lot of my owr stuff. Tuners, Amps, and such. What I need to know is what is a good lubricant for inductors and ver. caps that will not effect them electrically? I have a noisy inductor (machanically).
Thanks'
Don, W5KG
KA4POL
« Reply #1 on: March 15, 2013, 07:34:30 AM »
I use Ballistol.
K6AER
« Reply #2 on: March 15, 2013, 08:05:52 AM »
The problem with any lubricant is it attracts dust.  On roller inductors I keep the contact area as clean as possible. Sometimes you might need to polish the inside contact area. This can also be a problem if the contact area has been silver polished.
Working on a roller inductor is like working on a watch.
N4CR
« Reply #3 on: March 15, 2013, 10:55:33 AM »
Clean the moving parts as best you can. If there is a finger on a ball bearing on the end of one of them, there is conductive grease for that.
http://www.mgchemicals.com/products/greases-and-lubricants/conductive-greases/carbon-conductive-grease-846/
I clean the wheel and the shaft on the roller inductor with alcohol and then put a drop of MMO on it. That has to be redone about once a year.
I haven't tried the grease on the shaft and wheel. It might be just the ticket.
73 de N4CR, Phil
Never believe an atom. They make up everything.
K0CWO
« Reply #4 on: March 15, 2013, 12:17:20 PM »
I use GC Electronics Tunerlub Part No. 10-2610
WX2S
« Reply #5 on: March 16, 2013, 03:57:08 AM »
Just an idle thought. I wonder why they don't put the whole mechanism in vacuum? it's technically possible now with stepper motors.
Wx2s.
73, - Steve WX2S.
I subscribe to the DX Code of Conduct. http://dx-code.org/
« Reply #6 on: March 16, 2013, 04:17:48 PM »
Simple answer. Cost.
W5KG
« Reply #7 on: March 30, 2013, 07:00:56 AM »
Thanks to eveyone for the info.  Grin
Don, W5KG
