Author Topic: kenwood d710a Avmap 5 not plotting received stations  (Read 12027 times)
N5VEI
« on: March 17, 2013, 11:35:56 AM »
I have a d710a and Avmap GS5 with updated firmware that is not working like it should. The GPS is working and the radio beacons as well as decodes all signals received. However the Av map is not plotting them nor is it showing any call signs. Kind of like it is not communicating from the radio to the avmap. I went into the Avmap and cannot see any contacts even though I put an independent APRS beacon in the yard. The radio decodes it, but the avmap just shows the usual driving stuff. No call sign was shown or any indication that it has anything to do with APRS. I have gone through all the menus and setup what I found in the instructions as well as the stuff on YouTube. I need help getting this thing to work. Any suggestions?
Bill R.
N5VEI
W5LZ
« Reply #1 on: March 21, 2013, 08:08:51 AM »
I'm not familiar with the Avmap GS5 at all so take this with a large dose of salt.
I think you've pretty well defined what's happening (not happening) so it sounds like the thing just isn't communicating with the '710 for some reason.  If it were me (knowing me), I'd start checking connections, and going through those menus again.  Unless the thing is 'broke', there's got to be something not set correctly, or a missed connection somewhere.  Not much help, I know, but what other possibilities are there?
 - Paul
WN2C
« Reply #2 on: March 29, 2013, 08:12:43 PM »
Have you brought out or expanded the range of the map sp that you can see a wider area?
Rick  wn2c
KC2DLR
« Reply #3 on: May 12, 2013, 02:47:06 PM »
I'm no expert either, but is the gps indicator blinging on the face panel screen? Gps baud rate on 9600? Actually w6gps has some utube videos that helped me set up my g6. They are pretty handy! 73, good luck
