Author Topic: USB CW interface for contest logging programs  (Read 3528 times)
« on: March 19, 2013, 07:09:55 AM »
Is there a simple, inexpensive interface to go between a USB port and the CW jack on a radio to allow contest logging programs like N1MM and NA to be used as a memory keyer?
John AF5CC
N4UM
« Reply #1 on: March 19, 2013, 07:44:30 AM »
Yes, first you'll need a usb to serial port adapter and then you'll need a cable connecting the serial port adapter  to the rig's key jack.  K1NU used to sell them but I think he may have stopped.  You can order one from N3FJP.  I forget who makes the ones that K3FJP sells.
N7SMI
« Reply #2 on: March 19, 2013, 10:37:59 AM »
WinKeyer USB - http://www.k1el.com/ I think this is pretty much the standard contest keyer. Easily set up with N1MM or pretty much any other contesting software.
K3TN
« Reply #3 on: March 20, 2013, 02:58:23 AM »
I also recommend K1EL's Winkeyer. If you want something more general purpose, W3YY has a board kit that is a nice interface for CW and FSK keying  - look here.
John K3TN
AB3CX
« Reply #4 on: March 26, 2013, 01:39:57 PM »
I use a West Mountain RigBlaster
ZL1BBW
« Reply #5 on: June 04, 2013, 02:37:22 AM »
After a bit of thought, I ordered and built the winkeyer, its the best x dollars that I have ever spent.  Use N1MM with it straight off, very little messing about.  Getting used to a all keyboard operation takes a bit of doing, but its a real revolution. Smiley
N2IW
« Reply #6 on: June 04, 2013, 10:40:21 AM »
If you want to spend $78 for a Winkey keyer, and you can solder, you can make a cable with just a 1k register a 2n2222 a DB9 connector an audio connector and an USB-RS232 adapter of course. I use a cable just like this, if your computer is fast enough, it will work pretty well.
The circuit can be found in N1MM manual. Some USB-RS232 adapter make a lot noise, I use a Keyspan USA-19HS, it is very quiet and stable, but if you use your contest log software in a VM like me, it is a little bit tricky, you can use VirtualBox, you have to use Parallels Desktop ( I haven't try VMWare yet, so I don't know if VMWare will work or not )
NQ3X
« Reply #7 on: June 04, 2013, 07:00:03 PM »
RigBlaster Plug-n-play here.  CW, rig control, and digital modes all in one box.  Works fine with N1MM, which is all I use.
Caveat: It does not do true FSK, only AFSK.
73 de Bob WP2XX
K8GU
« Reply #8 on: June 05, 2013, 06:18:42 AM »
Another vote for both the WKUSB from K1EL and the serial/parallel port transistor/resistor keying circuit described by N2IW.  I used the simple circuit for many years with DOS-based logging software.  I've never used it with Windows, but I know a number of people who have.  The WKUSB is nice if you are accustomed to sending with the paddles frequently because the speed tracks the memory/software keying speed.
I now use the YCCC SO2R+ for my contest keyer (which has K1EL functionality) and keep the WKUSB around for Field Day and backup.
N0IU
« Reply #9 on: June 06, 2013, 03:59:20 AM »
You don't say what kind of computer you are using, but I have a "vintage" PC (meaning its more than 5 years old!) that still has PCI slots and I put in a PCI card with 2 serial ports. (I use 1 for CW and the other for FSK RTTY) The last time I checked, Newegg had them for $10. The "interface" for CW uses just one general purpose NPN transistor and one 1k ohm resistor that was built "dead bug" style directly on the back of a DB9 connector and easily fits into the shell.
Here is a link to a graphic with the schematic: http://docs.win-test.com/w/images/f/fa/Schema_COM_InterfaceCW.gif
Yes, it does work with N1MM!
