Author Topic: Tuning a linear into a dummy load  (Read 13526 times)
KM3F
« Reply #15 on: March 22, 2013, 01:53:15 PM »
A point that nobody seems to pay attention to.
You hear a tune up by the tone.
That station is 'not' on  or zero beat to your frequency.
Why, he is either up or down frequency but within the 'passband' of your receiver and causes more QRM than if it were right on 'zero beat' to your frequency. It make be laugh to hear comments about tuning the tuner-upper will never hear.
Said another way, moving up or down 'less' than 4000  to tune will cause QRM to the intended frequency.
When you tune, move 5 or more and then you may still cause QRM to some other QSO for the same reason.
Tuning an amplifer: Are you gong to tune directly into a load for a tank match to 50 ohms?
Then return to the Tuner and tune again for it's best setting?
That's two actions.
Everybody wants to see a flat match when 99% of the time it's not necessary unless your antenna system is so bad with common mode feedback that it causes audio problems. If so, fix the antenna and understand what your doing with all this..
Good luck.
KC4MOP
« Reply #16 on: March 23, 2013, 12:06:15 PM »
That's two actions.
Good luck.
Really a pretty good idea to reduce the deafening tone of tuner-upper. Zero-beat and quickly make adjustments.
I'm gonna try that from now on.
TNX
Fred
KH2G
« Reply #17 on: March 30, 2013, 01:12:35 PM »
Regarding the dummy load rating. Let us not forget the difference between PEP and AVG DC INPUT. 1500W PEP is not 1500 W out of the amp except on peaks which are of short duration. Peak Envelope Power  is not Average Power .A KW Dummy load will handle 1500 W PEP with no problem unless you stay key down for extended period. The Heath Canteena was Rated under AVG DC INPUT Smiley
N4CR
« Reply #18 on: April 01, 2013, 04:11:47 PM »
This is a thread about tuning an amp into a dummy load. Nobody tunes an amp with voice input.
73 de N4CR, Phil
Never believe an atom. They make up everything.
KD0UN
« Reply #19 on: April 03, 2013, 04:13:21 PM »
Real world:   Initial settings obtained on a dead band.  In the future return to logged settings and tune for max with a series of dits. 5-10 seconds on a clear freq.
WB5PGX
« Reply #20 on: April 04, 2013, 04:12:25 AM »
So, are you saying it is ok with an amp to just tune into the dummy load and then switch to the antenna and transmit without tweaking as long as the antenna is fairly resonant?
NO2A
« Reply #21 on: April 04, 2013, 07:43:28 PM »
I would retweak the plate cap just to be sure. It only takes a second and will give you piece of mind.
W9KDX
« Reply #22 on: April 06, 2013, 04:49:49 PM »
Thanks again for all the feedback.  As it takes me just seconds to do the complete tune up and most here agree that you need to re-tune on the real antenna, it kind of makes no sense to waste time on a dummy load.
Sam
W9KDX
NA0AA
« Reply #23 on: April 08, 2013, 07:57:21 PM »
Since I'm using a tuner into a 160 meter loop, I always have to tune the tuner first - and what I have found with my AL-80B is that provided I'm close to 1:1 on the tuner, I can use my pre-set numbers and get so close as to not worry - these pre-sets all developed with dummy load and some on-air testing with dead bands.
