Author Topic: Ant Tuner ??  (Read 2811 times)
N0TJO
« on: March 22, 2013, 08:44:23 AM »
I am using the Hustler 4BT Vertical antenna. Its ground mounted and according to my SWR meter (w/o tuner in line) it is <1.5:1. As a test with a new rig (450D) I hit the antenna tuner button and it wouldn't tune...just kept rattling. I switched out the rig with my backup FT 890AT and it did the same. Why will neither rig find a tuned spot with the antenna tuner when without the tuner its almost 1:1 already?? is there an actual problem or is it normal?
Any feedback appreciated. Brian/W4ZGH
« Reply #1 on: March 22, 2013, 08:47:30 AM »
Do the rigs have built-in SWR meters?  If so, what to they read?
I would expect either rig to be able to match the antenna.  Since
neither does, I'd first suspect that, while your SWR meter shows
a low SWR, the rig is not.  That leads me to suspect the jumper
cable between the SWR meter and the rig - perhaps a poor
shield connection?
As a test, can you unplug the coax from the SWR meter and
connect it directly to the radio?
N0TJO
« Reply #2 on: March 22, 2013, 09:33:34 AM »
Im using an internal SWR meter on both rigs. Both meters show <1.5:1 swr w/o tuner. Niether rigs tuner will "tune" the antenna...switches rattle but wont tune.
K2DC
« Reply #3 on: March 22, 2013, 12:48:11 PM »
I have seen other inboard auto-tuners that are not happy trying to match a low VSWR to a better VSWR.  It shouldn't be a concern if the VSWR is already <1.5:1.  Just leave the tuner turned off and let the rig do it's thing.  You can't hurt anything, and the mismatch losses are minimal.
Don, K2DC
« Reply #4 on: March 22, 2013, 03:11:13 PM »
Don, K2DC
Ditto.  I've seen this effect also.  Seems the algorithms (code) in the controllers aren't always equipped to deal with an already-low SWR.  Just turn the tuner off and use the rig.
N4NYY
« Reply #5 on: March 22, 2013, 03:28:14 PM »
Don, K2DC
I have an FT-950 and it will tune even with an already low SWR. I can see some programming telling the rig not to tune if the SWR is already low. But definitely not in my FT-950.
Now, I cannot recall for sure, but my Icom 746 may have behaved in the manner you mentioned.
W5LZ
« Reply #6 on: March 23, 2013, 03:37:43 AM »
I've had several radios do the same thing.  Basically, it's telling you that you don't need to use the tuner, it's not required.  So don't use it.  There's no practical/significant difference between a 1.5:1 and a 1:1 SWR.
 - Paul
