Author Topic: Intermittent painting on PSK 31  (Read 11068 times)
W5KAP
« on: March 26, 2013, 04:45:49 PM »
Guys, I am one frustrated op.  I am using a Rigblaster Plus which I purchased at Dayton in 2005.  My rig is a Kenwood TS-2000 and I'm using a Toshiba Laptop. Since my computer does not have a serial port, I purchased the serial to USB cable from West Mountain Radio and downloaded the driver.  I believe the jumper are correctly set as well.  No matter what I iuse for input, audio out from the rig, the front mic on the computer or a mic plugged into the comnputer and set in front of the outbaord speaker I run, I get consistent intermittent lines on my waterfall display and it won't consistently read out.  I have tried playing with AF gain, RF gain you name it and I simpy can't get anything to paint tes=xt for more than a few letters.  Oh, and is doesn't matter which sofware I use either.  I have WinMix. DM680, and several others all of nwhoch don't work.  What the heck am I missing.  I used to be able to hold the mic up to the speaker and make PSK contacts before I started using this laptop!  Yout thoughts would be greatly appreciated.
73 dE Kenn  W5KAP
73 de Kenn
N4CR
« Reply #1 on: March 26, 2013, 05:05:37 PM »
If you set the waterfall to listen to the internal microphone and whistle, does the trace get intermittent?
73 de N4CR, Phil
Never believe an atom. They make up everything.
W5KAP
« Reply #2 on: March 26, 2013, 05:21:36 PM »
Yes I still get the breaks but it is definitely better.  I can see  a noticable difference/  Sound card proble???
73 de Kenn
73 de Kenn
W5KAP
« Reply #3 on: March 26, 2013, 05:27:32 PM »
Phil, I tried it with 4 different programs and it does fine for a few seconds then drops out.  Perhaps a soundcard setting or something internal.  I know this shouldn't be so darned hard.
73 de Kenn
73 de Kenn
N4CR
« Reply #4 on: March 26, 2013, 05:47:45 PM »
This is a problem in the computer. Try a cheap USB sound card as a substitute.
Something like these would be suitable replacements...
http://www.amazon.com/Behringer-UCA222-U-Control-Ultra-Low-Downloadable/dp/B0023BYDHK/ref=sr_1_9?ie=UTF8&qid=1364344533&sr=8-9&keywords=usb+sound+card
http://www.amazon.com/Turtle-Beach-Advantage-Headset-Adapter/dp/B0036VO4XO/ref=sr_1_cc_1?s=aps&ie=UTF8&qid=1364345065&sr=1-1-catcorr&keywords=amigo+II
http://www.amazon.com/Logitech-3-5mm-Jack-Audio-Adapter/dp/B0058P0I2C/ref=pd_cp_e_1
One has RCA and all have 3.5mm mini plugs in/out. Any of these and dozens of even less expensive ones would replace the flaky sound card in the computer and provide a permanent solution.
73 de N4CR, Phil
W5KAP
« Reply #5 on: March 26, 2013, 05:50:49 PM »
I was leaning toward the sound card as erveything else seemed to be right.  I'll check those out. Thansk for your help@@
Cheers, Kenn
73 de Kenn
« Reply #6 on: March 26, 2013, 09:05:05 PM »
73 de Kenn
Tell us about laptop, memory, OS and CPU
W5KAP
« Reply #7 on: March 27, 2013, 08:41:26 AM »
73 de Kenn
The laptop is a Toshiba L505 Satellite using the M330 Intel Processor at 2.13 GHz, 4 GB of memory, 64 bit system using Windows 7.  I am this close to ordering the USB soundcard as suggested by another ham on here.  I took the plugged in mic offline and whistled into the built in mic.  it works fine for a few seconds, then frops out.  Sometimes when I have a strong signal painting, it is seen then looks like a hole in the waterfall.  Almost like its overdriving but it isn't splattering it like a negative just leaves like a negative paint if the makes any sense..  I'm thinking it is either the soundcard or some setting that I'm not aware of either on the soundcard or something. When I was using my TS-440 (which had an AFSK out port) and my old desk top, things seemed simple.  I'd just like to work some PSK and RTTY.  I have fun DXing on SSB but since I;m now retired, I wanted to play with digital.  If I wanted this much frustration I should go back to work hehehe
Thsanks for your help
73 de Kenn
New Braunfels, TX
73 de Kenn
W5KAP
« Reply #8 on: March 27, 2013, 04:11:48 PM »
Phil, I ordered the Turtle-beach unit off Amazon today  Should have it by Monday.
Thanks again for your patience and help
73 de Kenn
73 de Kenn
N4CR
« Reply #9 on: March 27, 2013, 09:37:05 PM »
73 de Kenn
Any time. Don't be at all amazed that the internal sound card flaked out on your laptop. They are really made from the absolutely cheapest chips they can find. They have it there so they can say they have one. Quality is not one of the requirements.
73 de N4CR, Phil
W5KAP
« Reply #10 on: April 02, 2013, 06:27:40 PM »
I snet Phil an email note thanking him as the USB card did the trick.  Thanks to all who looked at my ramblings
73 de Kenn  W5KAP
73 de Kenn
