Author Topic: IC-471 SQL problem  (Read 5559 times)
HG5AZR
« on: April 01, 2013, 02:41:37 AM »
Hi!
SQL open at 8 clock and close at 9 clock position .
After 10 minutes open at 9 clock and close at 10 clock position .
After 20 minutes open at 10 clock and close at 11 clock position .
After 30 minutes open at 11 clock and close at 12 clock position .
Sometimes open at 9 clock,closed at 3 clock position.
Sometimes SQL always open in all position of SQL pot,never closed.
1.Why is difference between open and close position?
2.Why  changing the  difference between open and close position?
Thanks
                  Zoli
W9GB
« Reply #1 on: April 01, 2013, 07:04:18 AM »
Icom IC-471A
http://www.universal-radio.com/catal...ulti/471a.html
Icom IC-471A/E/H Service Manual
http://www.ko4bb.com/manuals/index.php?dir=ICOM
Assuming the internal DC voltages are stable (well regulated),
You have a component (resistor, capacitor), in the squelch circuit, that is changing value.
This value change could be a thermal (heat) issue OR a leakage issue (capacitor).
Standard troubleshooting with service manual, schematic diagram and
bench test equipment required.
w9gb
KE3WD
« Reply #2 on: April 01, 2013, 07:13:44 AM »
First suspect would be a dirty or dry Squelch Control Potentiometer.
So the first thing to try is a control cleaner/lubricant such as Deoxit or equivalent on the control, from the inside.
WN2C
« Reply #3 on: April 02, 2013, 09:36:32 AM »
If the radio has not been used for some time, just turning the pot several times may be enough to clean it but you may need to use a shot of some cleaner.
Rick  wn2c
HG5AZR
« Reply #4 on: April 02, 2013, 10:02:02 AM »
Hi all!
Thanks for it but I think it is other problem.
IC-9A is SQL IC for SSB (4558) on pin 1 voltage is 0.98V,after same minutes 1.5V.
I replaced IC to new one and C225 2.2microF electrolit capacitor also replaced but after replacement same problem.
Thanks
             Zoli
