Author Topic: K3 and Signalink USB *help*  (Read 6600 times)
AD9DX
« on: April 01, 2013, 03:55:11 PM »
Ok I know the argument that I don't need it, but I like to listen to music while I work JT-65 so unless I want an OO report about broadcasting Led Zeppelin on the ham bands, I am going to need your help.
I purchased the special three plug cable that goes from the Signalink to the K3 and installed the circuit board to the appropriate place.  I can RX just fine, and but I can't get it to transmit.  Well, I can get the Signalink to do its part, and I can see the LED on the K3 light up TX but no output.  I did set the MIC+LIN to "on" but that is the only change I have made.
Any input on how your K3 and signalink are set up would be greatly appreciated.
EX, KC9TRM, KB9IRZ
WA9AFM
« Reply #1 on: April 01, 2013, 06:39:38 PM »
Check you 'Line In' gain menu; it is set to zero by default.
« Reply #2 on: April 01, 2013, 06:49:59 PM »
Yes, your indications are that the audio is not getting thru the K3. The SignaLink-USB uses the audio in a vox circuit to generate the PTT signal. If the K3 is keying then your software is creating audio out of the SignaLink so its an audio problem between the SignaLink and the K3. Line in gain set too low is very likely.
AD9DX
« Reply #3 on: April 02, 2013, 04:10:31 AM »
Thank you both for the responses. I'll check that tonight.
EX, KC9TRM, KB9IRZ
KH6DC
« Reply #4 on: April 02, 2013, 05:58:33 PM »
1. Check the TX knob on the Signalink, it may be turned to a minimum and adjust to just tripping the ALC for a clean signal output
2. Check to see if the speaker output selected from the sound menu is USB CODEC
3. Check the volume out from the sound card, maybe the level's too low
Hope you got it working by the time you read this.
73 and Aloha,
de Delwyn, KH6DC
AD9DX
« Reply #5 on: April 03, 2013, 09:36:55 AM »
I did not have a chance to work on it last night.  I ended up working a double and a half... 20 hours. I will probably look at it tomorrow now.
EX, KC9TRM, KB9IRZ
AD9DX
« Reply #6 on: April 04, 2013, 03:42:56 PM »
I was able to get it to transmit today... I still need to tweak things a bit but so far so good.
EX, KC9TRM, KB9IRZ
N4HAL
« Reply #7 on: April 14, 2013, 12:56:16 PM »
Need to set the data mode NOT to pSK but to DATA A to get it to work.
Hope his may help.
Bill
