Pages: Prev 1 2 3 4 5 6 [7] 8 Next   Go Down
Author Topic: Windows XP - the end approaches......  (Read 70660 times)
« Reply #90 on: May 24, 2013, 08:16:53 AM »
Tell that to NASA.  Laptops on the International Space Station are going to be fitted with Debian 6.  Windows is done on the ISS.
Not for reasons you think. They can modify and tweak Debian code for their needs and not windows and they have ability to write custom apps for it. This is far beyond average user ability.
WW7KE
« Reply #91 on: May 24, 2013, 08:53:42 AM »
Yes, you're correct.  I had heard some stories about a virus issue, but that's not substantiated.
But that's an advantage of using Linux over Windows.  Not everybody needs it, of course, but some do, including my employer, an office phone systems company.  We use both Windows Server and Linux in our products, and Windows will be going away in the next year or so due to high licensing costs.  That's another Linux advantage, especially in business (but not in the consumer space, where Windows is preinstalled on PCs and the lower single-machine licensing costs are factored in).
He speaks fluent PSK31, in JT8...  One QSO with him earns you 5BDXCC...  His Wouff Hong has two Wouffs... Hiram Percy Maxim called HIM "The Old Man..."  He is... The Most Interesting Ham In The World!
KY6M
« Reply #92 on: February 18, 2015, 08:19:04 AM »
My Windows XP still receives new security updates from Microsoft often!  Grin
VK6IS
« Reply #93 on: February 19, 2015, 05:16:32 AM »
Just fixed up a win_xp PC today,
& it received Nine Updates, - once it was connected to 'net.
- it's old, & has insufficient Ram to run SP3 correctly,
so - it's quite slow.
suggested that the cheapest fix, was to up the Ram, so it's closer to 1Gb,
or buy a tablet   Sad
But - the tablet wouldn't do everything that they could on the PC,
& a notebook would be even more expensive.
- the OP can't afford much.
maybe one of their children ( grown up ) can buy them win_10,
- when it comes out ??
doubtful, at best.
- there is a surprising amount of OPs like that, around the place,
and they can't afford to keep "upgrading"  Shocked
so - they haven't.
G8YMW
« Reply #94 on: February 19, 2015, 05:48:32 AM »
Ram chips are cheap enough, you just need to get the correct chips. If the computer is a bought unit, Google the model for the specs and "Slam in the ram" up to 4 Gigs (assuming the XP is 32 bit which is by far the most common).
73 de Tony
Windows 10:  Making me profane since March 2017
« Reply #95 on: February 19, 2015, 10:01:54 AM »
Actually a 32 bit OS will only see about 3.2 gigs so expanding beyond 3 is kinda pointless. As far as it helping, long ago I found XP gained nothing past 2 gig but Vista and 7 gained going past 2 gig.
G8YMW
« Reply #96 on: February 19, 2015, 11:17:18 AM »
Yes I'm aware of that although IIRC it does vary up to about 3.5 Gig. The advantage is he will have options if he decides to change O/S.
Next time I'm at home, I'll have a look at my desktop
73 de Tony
KK4GGL
« Reply #97 on: February 19, 2015, 11:21:13 AM »
... which is why the 6 gigs in my 32 bit Debian system is recognized.
Maybe that has to do with OS bloat.
Rick KK4GGL
« Reply #98 on: February 19, 2015, 11:39:05 AM »
Oh how blind.  The OS CANNOT see/use more than about 3.2 gig period. The only way it an use any of it is by paged bank switching. It CANNOT see or use more than 3.2 gig contiguous. You would know this if you knew anything bout 32 bit OS's but obviously you do not no surprise. 32 bit servers of days past used bank switching and a special Xeon CPU with a 48 bit address register that allowed it to track and bank switch on fly several gig of memory.
AG6WT
« Reply #99 on: February 19, 2015, 01:19:52 PM »
Through Physical Adress Extension (PAE), a 32-bit OS on x86 CPUs could address more than 4Gb of RAM.  The 32-bit Linux kernel has had PAE support for a number of years now and can handle up to 64Gb.  Windows XP had it initially but due to numerous driver problems they limited 32-bit XP, Vista, 7, and 8 to 4Gb.  If you have more RAM you have to use 64-bit Windows.
PAE was first implemented in 1995 with the Pentium Pro.
So, 32-bit Debian can use 6Gb.  However, the virtual address space is limited to 4Gb so a single process can't use more than 4Gb.
http://en.wikipedia.org/wiki/Physical_Address_Extension
AG6WT
« Reply #100 on: February 19, 2015, 01:25:08 PM »
or buy a tablet   Sad
doubtful, at best.
so - they haven't.
For a system that old with that little amount of RAM, I recommend installing a light weight, currently supported, Linux such as Xubuntu 14.04.  I'm using Xubuntu 14.04 on a computer with 1 Gb RAM and Intel Atom CPU and it works just fine with Firefox, Chrome, and Libre Office.
« Reply #101 on: February 19, 2015, 03:16:46 PM »
Your are wrong here as addressing and using is two different things which you do not understand. You must bank switch/page memory with 32 bit OS past 3.2 gig period... You CANNOT use as contiguous or flat memory access more than 3.2 gig at a time!!  It was not until the birth of 64 bit OS was FLAT memory access possible past 3.2 gig. Wishing will never change this. One of the driving factors to move to 64 bit it to smash the 3.2 gig flat memory barrier.
AG6WT
« Reply #102 on: February 19, 2015, 09:16:23 PM »
I have to make a correction here wrt 32-bit Linux with PAE.  In this case a single process can only address 3Gb with the remaining 1Gb of the 4Gb address space reserved for the kernel.  If you tweak the kernel settings you give more space to user space processes but I think 3.5Gb is the practical limit.  With 32-bit Linux PAE with more than 4Gb physical RAM, the OS can use that extra RAM for multiple processes, each restricted to 3Gb.  This is why the above mentioned 32-bit Debian can use 6Gb.  The advantage here is that if I have several processes running at 2Gb each on a 8-16Gb computer, the OS can keep them in RAM and won't have to resort to disk swap.  If I do hit the swap limit, I can add more RAM up to a total of 64Gb.
To get above the 3Gb per process limit, one must migrate to 64-bit Linux.
In contrast, 32-bit Windows desktop (but not some server editions) won't allocate more than 3.2Gb for all user processes.  RAM beyond 4Gb is inaccessible.
VK6IS
« Reply #103 on: February 22, 2015, 07:58:28 AM »
PCs of this vintage, generally won't recognise anything above about 2Gb ram.
- the OP is a pensioner & won't be able to pay that much, anyway.
they are favourable to the idea &  it will cost around $80 or so for a pair of 512Mb cards.
- it's also a laptop, which makes the upgrade even more expensive.
also moving to a Linux O/S which would be  desirable,
may not work, as the OPs 'net connection is a 3g dongle,
which may also be an issue with anything other than a heavy weighted Linux O/S.
- the lightweight DEs cut out support for 3g modems.
« Last Edit: February 22, 2015, 08:02:38 AM by VK6IS » Logged
« Reply #104 on: February 22, 2015, 08:05:29 AM »
Yes it is possible to bank switch with 32 bit OS but I see little point because the CPU can only use on chunk at a time with 32 bit and tasks in other chunks are paused until that page is active. I see no reason to use a 32 bit OS with more than 3 gig. The whole reason behind 64 bit OS is flat continue memory  access. Page swapping is a poor runner up.
Pages: Prev 1 2 3 4 5 6 [7] 8 Next   Go Up
